4th Gen dash swaps with LS1 engine INSIDE
Old Jun 5, 2007 | 06:24 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
I need help, i've tried everything. I have my engine running fine, and the dash swap is all mounted and almost wired up. I can not get the tach, gas, and water temp gage to work, as well as the odometer. These all recieve thier signal from the PCM, the serial data is connected to the PCM, why will it not work???
Does anyone have an LS1 motor with a 4th gen in and working? What am i missing? It has to be something simple but i'm stuck in a corner, any help would be great!
Old Jun 7, 2007 | 02:01 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: 4th Gen dash swaps with LS1 engine INSIDE
ttt for you I would also like to know.
Old Jun 8, 2007 | 09:26 AM
Firebat's Avatar
Check your power wires and grounds. Are you using the same year of LS1 gauges with your LS1 computer. For example, the 98 gauges are different.
Old Jun 8, 2007 | 01:42 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah I agree. Check your power and grounds and signal wires. Take it one gauge at a time. Tach is easy because its just gotta have power, ground, and some connection to PIN 10 on one of the plus (white wire).
Just kinda go over it all. Its so easy to miss a ground with these things. I missed a teeny tiny ground wire on my LS1 swap that caused me about 45 minutes of agony.
Props to you for even trying to wire up the LS1 dash. That stuff intimidates the crap out of me.
Justin
Old Jun 10, 2007 | 01:49 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
When an exhaust shop tried to start my car with a dead emergency starter, they blew out my gauges. The only things that worked were the hard wired sensors, anything fed from the PCM was dead. Replaced the cluster and all was well.
Another cluster is a cheap thing to try before diving into the wiring.
Kevin
Old Jun 11, 2007 | 09:46 PM
SnkSknrZ28's Avatar
Checked and Re-Checked power and grounds that is alway the first thing i do. I dont think its my gauges that are blown becuase some work and some dont, the only ones that dont are the ones that recieve thier signal from the PCM which includes the Tach, Fuel level, odometer. They get thier signal thru the data link wire, i'm going to look into that wire hopefully i will find something, if not i may end up going with a custom panel of Autometers. The search continues.
Old Jun 11, 2007 | 11:10 PM
shr00m's Avatar
Re-read my message. I had the same thing happen. The cluster worked fine aside from the gauges fed from the PCM. The same thing you are experiencing.
Kevin D.
Old Jun 20, 2007 | 10:30 PM
SnkSknrZ28's Avatar
Hmm i hope thats not the case but i guess that is a last resort, thanks for the help shroom!
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
