Help - What tool do I need???
I'm replacing my 2 rear struts that hold up the glass hatch.
What tool do i need to unscrew the 2 large bolts located near the rear seat that hold the strut in palce?
Thanks for the help.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: Help - What tool do I need???
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
3 people is an average, I did it by myself, but that hatch is a heavy **** without those struts. Try to do one at a time if by yourself.
Axle/Gears: 9-bolt/3.45
Nah, you can do it by yourself.
You can only change one-side-at-a-time anyway. So as long as one side is still attached, all you'll need to support the side you're removing is whatever 'special tool' you've been using all this time to support the hatch when you've had it open with the weak struts. Mine was a wooden stick from a broom.
Yall are wimps
3 people? Come on
By myself Ive removed, set it against the wall, and reinstalled the whole hatch when i painted the car without damaging anything or having a hernia. Its not THAT bad
One person is plenty strong enuff to hinge it up and down a few times
Its a T-47
I can take a pic of a T-50 NOT fitting in there if youd like
The easiest way ive found is to remove the 2 9/32" bolts and let the struts drape over the taillights
Wad up a towel and put over the latch so the hatch doesnt squish the struts or crush them into your tailights
Now go inside the car and remove the big bolts on the struts
Install new struts in same fashion
reopen hatch and slide new struts over the stubs and put 9/32" bolts back in
Should take 15 mins
3 people? Come on
Its a T-47
Should take 15 mins
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Yall are wimps
3 people? Come on
Its a T-47
Should take 15 mins
3 people? Come on
Its a T-47
Should take 15 mins
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I've used a T-50 as well with results of breaking the bit, or stripping out the bolt if they are in very tightly since it never seats correctly. It's just so much easier having the correct tool. Supreme Member
Car: Pair of 92 Z28s
Ya you guys are too quick for me, i was going to hop in and comment on the T47, i have striped some torx before when i first got the car and didnt know. Also if all you have is a T50 just hammer it in some and use a breaker bar and youll be fine. My trick to doing them by myself was one side at a time also.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i did it myself with the broom stick method, worked fine.
tyeo098
Nov 30, 2015 06:27 PM
