electirc to no electric seats
Old Aug 27, 2007 | 10:54 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
me and my buddy got camaros i have an 84 camaro with electric seats and he has a 91 camaro no electric. does the tracks need to go with the seats? as electric seat goes with rack? also how hard is it to remove interior? thanks bill
Old Aug 28, 2007 | 06:51 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Re: electirc to no electric seats
think the tracks are connected to the seats on both models, and the entire seat/track combo is bolted to the studs coming from the floor...but it's been some time since i removed mine.
Removing interior depends on how much you're wanting to remove. Seats are easy, fronts are 4 nuts on each seat, rears are one bolt on each seat bottom...can't remember about the seat back, and if swapping from a split fold down, to a single fold down rear seat, you have to hack up the center pivots used on the split seat....if going the opposite way, you'd have to add that center pivot (but i wouldn't go that way)...best of luck.
Old Aug 28, 2007 | 01:25 PM
Engine: 355
im replacing my carpet with his and his seat there like mint
Old Aug 28, 2007 | 02:11 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
The seats are easy to remove. On the electric ones there is the connection under the drivers seat to disconnect. Do this after you have it unbolted because you have to move the power seat foward to get the back crews. Entire seat removal or install should take a half hour tops.
The tracks are attached to the seats and are the same for both kinds of seats.
If you are removing the carpet you have to remove the center console as well which may or may not mean disconnecting your radio. Nothing hard to remove console but make sure you know how to take your shifter **** off. And you will need that special tool to remove the seatbelt fixture by the door on the floor.
Old Aug 28, 2007 | 02:47 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I believe the seat belt retainer bolts require a T-50 torx(it's been awhile for me also) for both the retractor assembly and the receiver next to the console.
Old Aug 28, 2007 | 06:28 PM
Pocket's Avatar
Car: 91 Trans Am
Its a direct swap, you will have an unused plug to stuff under the carpet thou
Old Sep 1, 2007 | 05:36 PM
Engine: 355
yeah im taken al,l my old out and puttin the new in. wire harness will be gone with the seats
Last edited by billybob6110; Sep 1, 2007 at 05:39 PM. Reason: Automerged Doublepost
Old Sep 4, 2007 | 08:13 PM
Engine: 355
Does anybody know the seat belt torgue tool i will need?
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
