silverado dash?
Old Feb 1, 2008 | 08:01 PM
blasko1022's Avatar
silverado dash?
tried to use the search and couldnt find anything. doing an 5.3 swap from a silverado into a 92 and i wanted to try to use the gauges. is there anyone who can point me in the right direction? can it be done or is there another option i should look at?
Old Feb 1, 2008 | 09:21 PM
Stephen's Avatar
Car: 87 GTA
Re: silverado dash?
Probably can't find anything here, because this site is dedicated to 82-92 Firebirds & Camaros. Not much, if any, Silverado dash info here.
Old Feb 1, 2008 | 10:41 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Re: silverado dash?
your best bet would probably be http://www.fullsizechevy.com/forums/
or http://www.ls1truck.com/forums/
Old Feb 2, 2008 | 04:31 AM
blasko1022's Avatar
Re: silverado dash?
anomaly,
well thanx for the suggestions, i checked out the sites you suggested. unfortunately the only info they gave was swapping gauges in trucks, not how to put them into camaros. unfortunately, i will probbably have to fabricate a dash. i wanted to make it look factory, but seems impossible
Old Feb 2, 2008 | 06:05 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: silverado dash?
Don't give up so easily-
Have you checked the Silverado dash to see if someone like Auto Meter makes any guages close to the size of the factory units??? I'll be using a custom dash guage insert for my IROC and knew from the get-go, I'd have to locate a very reputable shop to oversee the swap. Do you have a picture of the dash we could take a visual of????? Nitro
Old Feb 2, 2008 | 12:34 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Re: silverado dash?
So you're putting the 5.3 into a 1992 camaro?.... Sweet, but I don't think the gauge cluster will work though. Unless it's different than my 02 Sierra gauge cluster?.... If the dimensions are close nothing is impossible.
Old Feb 2, 2008 | 12:55 PM
blasko1022's Avatar
Re: silverado dash?
took some measurements. i see no reasonable way of putting the gauge cluster in short of fabricating a sheetmetal or fiberglass dash. i could make it work but it would look like crap. so fiberglass install it is. so much for factory look
Old Feb 2, 2008 | 02:12 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: silverado dash?
Do a search for people that have put autometer guages in these cars. I have seen some really clean installs, that they use the stock firebird dash and remove everything behind the guages, and put them in. If you could get aftermarket guages that will preserve the stock 5.3 sensors / senders, but are the right diameter for these cars, that will be your best bet probably.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
