roll cage
Old Feb 11, 2008 | 10:26 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
roll cage
just wondering if anyone has one out there if so post pictures i would love to get some ideas on how you guys fabricated them and put them in so i can start making plans
Old Feb 11, 2008 | 10:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: roll cage
old thread, some pics are no longer there but its a start
https://www.thirdgen.org/forums/susp...light=roll+bar
check the manufacturers websites like spohn, competition engineering, etc for their cages and see them installed cars
Old Feb 14, 2008 | 08:19 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: roll cage
anybody else have roll cages or now where to go to get pictures of them???
Old Feb 15, 2008 | 05:51 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Re: roll cage
I recently had a 6 point roll bar custom made by one of my co-worker friends that has his own welding and fabrication shop on the side. I will try to get some pics on here soon. He did an awesone job and it is legal. We just need to finish it up by installing the swingout kits in both sidebars.
Old Feb 15, 2008 | 06:16 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: roll cage
here`s my old thread when I did mine, originally I did a 8 point, then went on to a 10. Lotsa pic`s in there....
https://www.thirdgen.org/forums/orga...-progress.html
Old Feb 21, 2008 | 05:01 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: roll cage
so anybody else working on one or already has one in???
Old Feb 21, 2008 | 08:09 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Re: roll cage
I can't seem to find a any of my 3rd gen pics! so here are some of my 4th.
I will be stripping the whole car down again and will have the roll bar changed to a 12point cage.
Attached Thumbnails roll cage-disc2-028.jpg   roll cage-show-20car-206-20point   roll cage-show-20car-206-20point
Old Feb 22, 2008 | 12:40 AM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: roll cage
12 point thats pretty crazy i dont need anything that serious i am just looking into what they look like cause i like the way it looks in a car
Old Feb 22, 2008 | 01:13 AM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: roll cage
antosh,
Its very dangerous driving with a cage in your car on the street. If you do get into an accident, God forbidding, you'll hit your head on the cage and that doesn't end up well. They run them on the track with helmets. You could use some creativity if your welder knows the proper techniques. Keep these concepts in mind when you make your decision.
Rabi C.
Old Feb 22, 2008 | 02:03 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: roll cage
6 point would be fine on the street since your head can't go back that far with a 5 point harness on tight. If it's street driven I wouldn't do a 10 point due to it crushing your skull without a helmet in a side impact.
Old Feb 22, 2008 | 01:32 PM
2fast4u92z's Avatar
Re: roll cage
Originally Posted by onfire
antosh,
Rabi C.
If you look at mine it is very hard to hit your head on anything. Rule book says side bars have to be between shoulder and elbow. And there is a rule about where the hoop is but I can't remeber? with a 10 or a 12 I can we that happen. My 4pt sparco harrness and Sparco seats keep me save.
I Know my roll bar is a little crazy with all those bars but it was going to be a 12pt but my fab guy had to leave town(racing) last minute and I was in a hurry to get to the wiring guy. Still "best deal ever for $1500 chromemoly roll bar with fuel door,painted,nitrous bottle brakets, and removed gas tank and lots of extra factory steel. Oh and the whole roll bar is measured in front of me to be within 1/8" same everywhere!
And so everyone knows a 4pt or a 6pt is a ROLL BAR.
And when there are bars over head and down the a-piller it is a CAGE.
Old Feb 22, 2008 | 02:18 PM
onfire's Avatar
Car: 88 Formula 350
Re: roll cage
I agree if done properly you can avoid hitting your head but definitely keep that in mind when your routing your cage. You don't want to hurt yourself on something that supposed to keep you safe! Yes you would want to take advantage of your bar/cage by getting the 5points. Do you have sfc?
Rabi C.
Old Feb 23, 2008 | 01:03 AM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: roll cage
yea i wasnt going to plan out anything crazy and i know the dangers of it but the real reason is i want to be able to get some racing seats and then be able to get a harrness in there and use it the correct way
and thanks for your opinions
Old Feb 23, 2008 | 09:40 PM
onfire's Avatar
Car: 88 Formula 350
Re: roll cage
antosh,
Post some pics along the way. I'm interested to see how it'll turn out.
Rabi C.
Old Feb 23, 2008 | 10:18 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: roll cage
i will it might take awhile casue i need to get some more money but i am not even out of high school yet so i cant make that much money a week but as my car progresses i will get on posting pictures
Old Feb 27, 2008 | 06:19 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: roll cage
thats funny about the whole bashing your head on a bar. but i mean if that bar isnt there youll most likely smash your skull into the roof or something anyways. and not to mention they do make pads that go around the bars. you can get them from summit, they got all kinds of colors also. so how exactly does a harness strap on a racing seat without a rollcage? do they bolt to the floor? wrap around the seat? and how effective is a roll cage? say in a collision or a car being flipped? jus wondering if anyone really knows the truth. thanks guys.
Old Feb 27, 2008 | 09:45 PM
2fast4u92z's Avatar
Re: roll cage
How safe is a CAGE?<-- I say very safe as the weakest part of a f-body is the front windsheld. And a cage protects that, however a roll bar doesn't. And roll bars is what we are talking about here.
The two works get thrown around so much that many people don't know the difference! and there is a world of difference.
Old Mar 30, 2008 | 09:36 PM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Re: roll cage
Is an 8 Point a roll bar or cage?
Old Mar 30, 2008 | 10:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: roll cage
bar
Old Apr 2, 2008 | 01:05 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: roll cage
I have pictures of my 12pt cage on my cardomain, if your interested.
Page 6.
Old Jun 3, 2008 | 06:36 PM
84ls1_transam's Avatar
Car: 1984 Pontiac Trans Am
Engine: LS1 Zex Direct injected
Axle/Gears: 4.88 Moser 9"
Re: roll cage
So at what point do you need a 10 point cage? I have an ls1 pushing about 400 horse, and a 200-300 shot of nitrous. I haven't taken it to the track because I think I would get kicked out, if they even let me run. I want to do a 10 point, but I have a-pillar gauges. Anyone have any ideas?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
