painless wiring harness and ignition switch
Old Feb 12, 2008 | 08:50 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i am thinking about getting this http://store.summitracing.com/partde...5&autoview=sku wiring kit and this http://store.summitracing.com/partde...5&autoview=sku or this http://store.summitracing.com/partde...5&autoview=sku ignition switch (gettin rid of vats and not sure which one is needed, if its the later of the two switched posted it will be mounted on the dash or something i guess) and totally redoing the wiring in the car. the owner before me totally hacked up the wiring so while i have the motor out and all the interior out i was thinking of replacing it. a carbed big block is goin in so F.I. wiring isnt an issue. i finished welding up the roll cage and i have my seats and everything so the interior is about ready to go back in unless i tackle this job too. what are some of you guys thoughts? does the plan make sense or am i wasting my time. also would their be a better way to do it? i really think i need a new harness so i dont really want to repair the old one. i searched but couldnt come up with anything on this specific topic per say. thanxs guys
Old Feb 13, 2008 | 04:53 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: painless wiring harness and ignition switch
anyone?
Old Feb 16, 2008 | 12:39 AM
84camaro400's Avatar
Car: 1984 Z28 T-tops
Engine: 406 Small Block
Axle/Gears: 3.73 9 bolt
If the guy before you hacked all the wiring up and you want to get rid of the stock mess anyway i would go with the painless wiring kit. I recently rewirid my whole car aswell to get rid of all the B.S. and it went in with out a problem everything is labeled and it has all the clips and connectors needed to go right to the colum. and if the interior is ripped out then i wopuld say this is a perfect time to do so. hope this helped...
http://www.painlessperformance.com/w...rchField=10201
Old Feb 16, 2008 | 12:48 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
im redoing my wiring and i just took my dash right out. im planning on making a custom gauge cluster.
how much does that wiring harness cost?
Old Feb 18, 2008 | 11:01 AM
I just bought another one for my second car and it was $400. summit wants$500 for it. but i found it at local speed shop to be cheaper. so shop around and see. if your dash is all out its a perfect time to do it. and like i said its real easy and it comes with everything needed
Old Feb 18, 2008 | 11:58 AM
joshh44's Avatar
Engine: engineless
yeah i did some shopping around.
and yes my dash is right out. its in my bedroom at the moment haha.
i was looking at my old wiring harness and so i decied to take it out as well.
anyways i just removed alot of the unessesary wires. since my car is TBI and im putting a carbed engine in. i just removed pretty much anything that was hooked up to the ECM. and just left the lights and what ever was hooked up to the gauges. thats pretty much all that i have. im thinking of redoing my wiring job tho. i found some more wires that i dont need at the moment. i ill take a photo of my self wiring harness once its fully complete.
Old Feb 18, 2008 | 05:15 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
awesome, i guess i will be tackling this job sometime in the next couple of weeks
Old Feb 26, 2008 | 05:45 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Axle/Gears: stock 10 bolt
have you done any of the rewiring yet. i have the same kit and am looking to do it to and was wondering how difficult it was.
Old Feb 26, 2008 | 06:44 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
to be honest with you i have not yet or even ordered the wiring harness yet. i thought i would be done with what i am currently working on right now on the car but it is taking forever.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
