B&M shifter
Old Mar 13, 2008 | 07:57 PM
Monica9's Avatar
Car: 87 Irocz
Engine: 5.7
B&M shifter
Ok guys so i had big problems getting the shifter to work properly and shift smoothly and i was told of sorts of solutions. What i did was send it to b&m and get a new sent back by them and now it works smooothly in all gears, so the problem was a defective shifter. If anyone is having this problem, its not normal for it to be hard to shift the gears and you might need to get a new shifter
Old Mar 13, 2008 | 08:37 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: B&M shifter
mine is stiff pulling from park to rev. Butfine in all the other gears. I kinda like it this way tho. I had my buddy back it up about ten feet, it took him a couple tries. he played with the ign, the steering wheel, the finger bar, couldnt figure out why it wasnt dropping back. I thought it was funny. i look at it as maybe an added security feature.
Old Mar 28, 2008 | 03:12 PM
dhink's Avatar
Re: B&M shifter
Thank you for this info I have an 86 Z28 and I am going to put a B&M shifter in some time soon, again thanks.
Old Mar 28, 2008 | 04:03 PM
Finetunedz28's Avatar
Re: B&M shifter
I didn't have any problems installing mine. Took a few times to get a good adjustment. Still deciding to whether or not to install one in my 87 too.
Old Mar 28, 2008 | 04:31 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Re: B&M shifter
hey guys, while on the subject, i dont mean to hijack the thread, but is the B&M hard to install? me being a total novice. i dont want to spend 200 bucks then mess something up, but i love the way it looks and since im gonna be redoing my interior i thought it would look pretty awesome in there. from what i understand, you must remove the entire console, then remove the stock shifter correct? then i heard something about shifter cables. please i try and understand this but if someone could tell me in NOOB terms, i would appreciate it. thanks
Old Mar 28, 2008 | 05:09 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: B&M shifter
I installed mine,Not hard just take your time doing it...Here is a step by step with pics:
http://www.iroczone.com/projshifter01.htm
Old Mar 28, 2008 | 08:31 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: B&M shifter
it was easy, id say a 2 out of 10.....although i did manage to mess up my gear indicator when i put mine in
Old Mar 29, 2008 | 01:16 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: B&M shifter
I see a lot of these shifters in camaro's anyone have pics of them in a bird??
Old Mar 29, 2008 | 01:35 PM
Re: B&M shifter
ONly real problem I ended up having was getting the indicator cable caught in the shifter. Ended up cutting it when I did. Wasn't paying attention well enough I assume.
Old Mar 29, 2008 | 01:38 PM
89RS-XXX's Avatar
Car: 1989 RS
Engine: something special
Re: B&M shifter
if you take your time you can use a dremel and cut out a small area infront of and to the side of the old consule so you dont hack up your interior, the shift indicator can be a big pain for sure. as for appeal you can beat the way they look... (based off '86 RS with the B&M Z-Gate)
Old Mar 29, 2008 | 08:47 PM
BMAN90RS's Avatar
Re: B&M shifter
any of you guys got pics of them in your car?
Old Apr 1, 2008 | 01:35 AM
Dominator87's Avatar
Car: 1987 Camaro IROC Z
Engine: 355 Crate engine Edelbrock Carb
Transmission: T56 six speed
Axle/Gears: 12 bolt rear 3.73
Re: B&M shifter
This was back when it was an auto... I have to admit that shifter was sweet but it's just not the same without a clutch
By dominator290, shot with X100,D540Z,C310Z at 2008-03-31
Old Apr 1, 2008 | 01:41 AM
Re: B&M shifter
As long as I'm at it, here's what it looks like now...
Old Apr 2, 2008 | 02:41 PM
89RS-XXX's Avatar
Car: 1989 RS
Re: B&M shifter
was it hard to do your guages like that? they look nice and I am intersted in trying myself. any pointers would be great
-John
Old Apr 2, 2008 | 10:19 PM
Re: B&M shifter
A friend of mine works in a machine shop so he made that piece for the gauges for me out of aluminum. I think I've seen something similar in a classic industries catalog but the hardest part was getting that piece to mount them on. Just get yourself a good wiring diagram and it's totally do-able. The auto meter instructions are usually really good so it makes it pretty simple to wire them up it's just very time consuming. Let me know if you have any other questions, hopefully that helps a little.
Old May 16, 2011 | 01:54 AM
ponchilaz's Avatar
Car: 1987 Camaro iroc z
Engine: 350 TPI 5.7L
Transmission: Automatic
Re: B&M shifter
was it hard to put the car from auto to manaul with the clutch? what do you need to do to put a car from automatic to manaul?
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
