Best Way to Remove the Shifter KNOB?
Old Sep 30, 2008 | 10:15 PM
sixty6's Avatar
Best Way to Remove the Shifter ****?
I need to remove just the shifter **** on a Camaro (mainly so I could just put it on mine) and I'm faced with 2 problems at the moment.
One, I couldn't take the plate that surrounds the **** without cracking it.
Two, I couldn't figure out what to do to remove the shifter ****.
I tried unscrewing it, and the top COVER came off, revealing another button...
Any help would be appreciated.
Old Oct 1, 2008 | 10:21 PM
UDAMON's Avatar
Car: Mazda Protege5
Re: Best Way to Remove the Shifter ****?
there is a clip in the front side of it that you need to pry out with a small flathead screwdriver. then it justs pulls right off.
Old Oct 2, 2008 | 03:09 AM
sixty6's Avatar
and I'm assuming the clip is UNDERNEATH the ****?
Old Oct 2, 2008 | 06:24 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
No, it is about midway down the shifter ****. You will see a slot in the shifter head/****. I used an angled pick. Once the clip is out, you may have to pull the **** straight up with some force. We are talking about an automatic, I assume.
Old Oct 2, 2008 | 09:52 AM
sixty6's Avatar
Yep
So the clip is in the head of the shifter ****, but I don't see it...Can I see it easily, is it the top, left, right or bottom side of the ****?
Old Oct 2, 2008 | 10:55 AM
Stephen's Avatar
Car: 87 GTA
Move your shifter ALL the way to 1st gear.
The clip is in the middle of the ****, about halfway down, on the FRONT. It's more of a "feel for it thing" than actually being able to see it easily.
Old Oct 2, 2008 | 03:19 PM
UDAMON's Avatar
Car: Mazda Protege5
Old Oct 2, 2008 | 07:34 PM
sixty6's Avatar
oh WOW, I can't believe I didn't see that...it seems odd that I didn't see that already, but that's not on the **** at all..
now I gotta go back to the junkyard and try it again
Thanks!
Old Oct 2, 2008 | 10:38 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Thanks!
Take the clip too. You never know when you may need one.
Old Oct 3, 2008 | 10:46 PM
sixty6's Avatar
Perfect advice, thanks for all the posts
The clip is pretty small, was kind of skeptic that I'd even find it
I thought I had to push in the clip (which definitely doesn't make sense now), but when I pushed, it slipped to the top and came out when I pulled out the screwdriver (luck..)
With barely a little force the **** just popped out! Went back for the clip too...
Thanks for the replies though!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
