Fog on Speedometer Cluster Please help!
Old Oct 11, 2008 | 12:39 PM
Jokerslye's Avatar
I just recently had my car detailed and the inside of my speedometer cluster was all fogged up , I opened up the windows and most of it cleared up but the speedometer cluster side is all fogged up ? I have used cleaning solutions inside and out of it and nothing seems to work anyone gone through this ? Anyone know how to fix this ?
Old Oct 11, 2008 | 01:51 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Fog on Speedometer Cluster Please help!
Get some meguires's plastic cleaner.
Old Oct 12, 2008 | 01:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is it fogged from moisture or just hazzing.You can sand it with 2k to 12k sandpaper.I bought some at a hobby store & Ive used it on my tailights & also the cluster lense.Then just buff the area afterwards.If it fogging!well then no cleaner will help.You have some warm air(heater maybe) or worse, water around the area fogging up the lense.Id remove the dash lid & see whats going on in there.Sory i dont have more to offer.
Old Oct 14, 2008 | 04:48 AM
Jokerslye's Avatar
What ended up happening is I got my car Detailed and then I didnt vent the windows . I came back the next morning and everything was fogged up on the lens so I wiped it off and then aired out the car and everything cleared up but the left lens for the speedometer part and its pretty foggy I can't see the speedometer that well . I tried this light cleaner and that didnt help . I am starting to think I have to try and find a new lens which I can't manage to find one anywhere..
Old Oct 14, 2008 | 12:59 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Theere should be lenses at a junkyard near you for like $5. Otherwise try the buffing method
Old Oct 14, 2008 | 03:11 PM
Jokerslye's Avatar
I tried lens cleaners and every cleaning solution and none of them work . I don't think there are any junk yards by me but eh i guess ill have to look into that.
Old Oct 14, 2008 | 07:10 PM
Kevin84Z28's Avatar
Well, that doesn't make sense. Your lenses were fine then you had it detailed and now it's foggy and you can't get rid of it? I have to ask...Have you taken the lens off and cleaned the reverse side of it? If thats the case, unscrew the face plate and it will expose the screws to take the lens off. Then you can clean the backside. When looking for parts don't forget the "parts wanted" threads on this site. Post a thread that you're looking for a lens and you'll get a ton of responses.
Old Oct 14, 2008 | 07:31 PM
Jokerslye's Avatar
I have taken the lens off and and wiped both sides nothing seems to work . I mean when you look close at it , It looks like its a bunch of small scratches which I just don't understand.
Old Oct 14, 2008 | 08:07 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
If theres small scratches go to a autostore and buy some plastic polish and polish it up
Old Oct 14, 2008 | 11:16 PM
Kevin84Z28's Avatar
you can even use "brasso" It's used on plastic watch crystals.
Old Oct 15, 2008 | 12:48 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Never knew you could use that on plastic. Does it get out tiny scratches?
Old Oct 15, 2008 | 05:44 PM
Kevin84Z28's Avatar
Yes, sometimes I get "You're Crazy," but read the back of the label, it's for small scratches in plastic. Works great. It's just an abrasive, like the sandpaper suggestion, just a lot more gentle.
Old Oct 26, 2008 | 12:02 AM
86irocterror's Avatar
i use 3m buffing compound for paint and clearcoat on plastic and it always works just fine. the key is to use the proper compounds for the depth of the scratches. i just recently did mine and mine were all fine scratches from cleaning with papertowls and stuff. so i just used a swirl mark remover compound and it is flawless now.
Old Oct 26, 2008 | 03:27 PM
Kevin84Z28's Avatar
Paper Towels are brutal on most fine surfaces on a car. Never use anything made out of wood on mine.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
