Couple Questions
Old Dec 20, 2008 | 12:30 PM
SovereignDragon's Avatar
Car: 1990 Trans Am
Engine: 305 TPI (for now)
Transmission: 700-R4 (for now)
Axle/Gears: 2.73 10 bolt (for now)
Couple Questions
alright, my 90 t/a was in rough shape when i got it. i've been slowly building my plans on what i want to do with it but i do know this, air conditioning is not in it's future. is there a special hvac controller (possibly 1le) that doesn't include controls for the air conditioning or would i just use a rotary switch to control the heat. also under the drivers side i think there is supposed to be a panel but i'm not sure. mine looks like something would bolt up. maybe to cover the fuse box and mount a spot for the diagnostic port. any help would be great.
Old Dec 20, 2008 | 12:51 PM
georgealtemus's Avatar
Car: 1987 gta trans am
Engine: 5.7l 350 supercharged and more
Transmission: 700r4 w/shift kit
Axle/Gears: moser 12 bolt w/373 aubern posi
Re: Couple Questions
I dont know about the a/c controller but there should be a cover for the fuse box and diagnostic port.
Old Dec 20, 2008 | 03:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A non-AC car should have what you need.
JamesC
Old Dec 20, 2008 | 09:46 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I know of two of the non a/c hvac controls. Only thing is they're still on the cars and right now its -9F. Way to cold to go to a picknpull. How do they remove? I know the obvious screws but what is conected behind them?
Old Dec 21, 2008 | 09:57 AM
Car: 1990 Trans Am
That's what I'm trying to figure out. If I get one of them what else will I need? I'm definitely wanting to pull the a/c right and make it look good.
Old Dec 21, 2008 | 10:01 AM
JamesC's Avatar
Kansas and no AC? I'd like to check you ride out when you return.
JamesC
Old Dec 21, 2008 | 10:28 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
James i think you've mentioned this before. If you use the HVAC without the ac, wont you need the internals of the dash as well? I thought i seen that the hvac with no ac will not work with a AC dash internals. Can you verify this?
Old Dec 21, 2008 | 10:56 AM
JamesC's Avatar
Sorry. No experience. I can verify, however, that the non-AC dash is different from the AC dash: No vent cutouts and a slider(s) under the dash that opens the vents.
JamesC
Old Dec 21, 2008 | 11:26 AM
Car: 1990 Trans Am
I know, no a/c is nuts in the midwest but when it's done it's going to be more of a weekend cruiser. If I get warm I'll just drop the windows and open the sunroof. Plus I don't like the cluster, it'll take away from the "look at me" factor of the engine I'm hoping to have done either in or before 2011.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
