How do you remove the headlight knob?
Old Jan 26, 2009 | 04:29 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
How do you remove the headlight ****?
How do you remove the headlight **** on the dash? Thanks
Old Jan 26, 2009 | 04:38 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Re: How do you remove the headlight ****?
On the back side of the **** it has a push spring. You just need to use a very small, skinny screw driver and push that in while your pulling the **** and it will pop off. If you put your head against the dash and look behind the **** you can see this small spring thing when you spin the **** around.
Old Jan 26, 2009 | 04:50 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
cool, Thanks im going to do that now..
Old Jan 26, 2009 | 05:10 PM
my82roc's Avatar
Car: 89 Iroc Convertible
There is a small cutout on the back of the **** where you can get screwdriver access to the clip.Once you push forward on it the **** should slide right off
Old Jan 27, 2009 | 10:12 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
This is how you remove the ****?
My stupid Chilton manual told me to remove the dash pad and hit some "release switch" on the headlight switch itself!
Old Jan 29, 2009 | 02:46 AM
z28_valencia's Avatar
This is how i removed mine :
First , remove the gauge cluster (for reaching easy the damn spring) (good time to lubricate speedometer cable) , look under the headlight switch , and push-in hard a spring with your finger, hold it , and pull-out the **** .
To install , push-in the spring , hold it and insert the **** in place.
Cheers , JF
Old Jan 31, 2009 | 03:36 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
JEEZ, do it the hard way...!!
1: remove the panel under the steering column.
2: get under the dash- looking up toward the headlight switch- and you will see where the headlight switch fits into the module. You will see a button sticking out of it, pointing down towards you...
3: pull the headlight **** out as if you are turning on the headlights.
4: using a screwdriver, rod or stick, depress that button.
5: while depressing the button, pull the headlight **** out of the housing- bingo!
Now, remove the dash panel, gauge cluster or whatever you are planning and temporarily replace the **** so you don't rundown you battery!
Old Jan 31, 2009 | 03:40 AM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
BTW, you do not need to depress that button to reinstall the ****- just push the thing in and it will lock in place!
Old Jan 31, 2009 | 02:52 PM
IrocZ_85's Avatar
Wow, all I did was removed the 2 screws holding the trim panel, pull the switch out and then stick a screwdriver through to the pin and push it up.
Old Jan 31, 2009 | 02:56 PM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
That is what I said! Perhaps I used too many words...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
