Speedhut Gauges
Old Feb 26, 2009 | 09:23 PM
Suaveat69's Avatar
Speedhut Gauges
Found these over at the GN forum. Can get them custom engraved and they have memory settings to boot.
Check out the Turbo 6 in the gauge.
http://www.speedhut.com/
In additon to recall of the tach and speedo, shift light and you can set warning lights for all the gauges
Old Feb 27, 2009 | 12:55 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Speedhut Gauges
Those would look really cool in a GN. Dont know how well they would look in a thirdgen. I'll stick with my autometer Pro-comp ultra's
Old Feb 27, 2009 | 03:03 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Speedhut Gauges
I'm glad I ran across this as I think I've found my gauges. I've been trying to figure out how I was going to tackle the T56 + cable driven speedo issue in my '88. I haven't really been turned on by the aftermarket options enough to let loose of $800. I wasn't exactly excited about paying $350+ to have my tailhousing modded for cable driven speed sensor output just to use the stock gauges.
The look of the gauges makes happy enough to spend the duckets...
Old Feb 27, 2009 | 09:54 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Speedhut Gauges
Gauges look EXCELLENT.
Definately know what im doin for gauges now
Old Mar 13, 2009 | 01:38 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Speedhut Gauges
Quick update: I just ordered the kit shown above and ended up with all the gauges for $683, free shipping and no tax. Lead time approx 2 weeks.
Old Mar 30, 2009 | 07:26 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Speedhut Gauges
Well, the gauges arrived today. I will say I'm mostly happy with these gauges just looking at them in the box. However, it looks like there is a small square raised area on both the speedo and tach. We'll see how it ends up looking when installed and lights on...
Old Apr 4, 2009 | 03:03 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: Speedhut Gauges
Vexter, those gauges look boss ! I am in the market for gauges now and had never heard of these, utterly awesome. Please tell me more about the install process. I was looking toward the dakota digital gauges because they have that "Plug everything into this" hub that I like. What is the install process on these ?
Old Apr 5, 2009 | 07:33 PM
odecca's Avatar
Car: 89 RS
Engine: 305... for now.
Re: Speedhut Gauges
Who makes those. I Have never seen anything like that.
Old Apr 6, 2009 | 08:50 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Speedhut Gauges
Omni - I haven't started the install yet. I'll be doing the gauges at the same time as the T56 install (almost ready for that). However, these don't appear to be strictly plug-and-play. Each instrument comes with it's own sensor and wire/cable. The only exception to this is the fuel gauge which uses the existing sensor.
I haven't figured out what I'm going to do about turn signal and high beam lights yet. I don't want anything like what's in the OP's pic. I need to get these mounted up in the Covan's panel and hook up some power to see how they're going to look.
Let me know if I can answer anymore questions.
Old Apr 8, 2009 | 08:40 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Speedhut Gauges
Ok, a couple more pics. Granted, my picture taking abilities could use some refinement, but you get the idea. I finally mounted the gauges in the Covan Panel and hooked up 12vdc in a dark room. The results are attached...
Attached Thumbnails Speedhut Gauges-mockup.jpg   Speedhut Gauges-reverseglo.jpg
Last edited by vexter; Apr 8, 2009 at 08:43 AM. Reason: Forgot the attachements...
Old Jan 12, 2010 | 01:44 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
Re: Speedhut Gauges
i know this is old, but how are the guages working? any problems? im getting ready to take this jump soon
Old Jan 18, 2010 | 07:57 AM
BadBowtie88's Avatar
Re: Speedhut Gauges
Looks pretty good so far. Any updates?
Old Nov 24, 2010 | 09:31 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Speedhut Gauges
Bumping this old post because Speedhut is having a sale this weekend. I'll be ordering tach.
Old May 19, 2012 | 08:37 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Re: Speedhut Gauges
any news on gauges holding up? i'm thinking of going to this set up very soon....red backplate, white numbers...white glow at night....
Old May 19, 2012 | 10:33 PM
Car: 1984 Firebird
Axle/Gears: 4.10
Re: Speedhut Gauges
so far so good, just rolled 7500miles the other day actually. The only thing that i have to report is that the tach will occaisionally get "lost" if you dont let it do its full sweep between turning the key on and actually firing the car. It hasnt bugged me enough to bother calling speed hut about it
Old May 20, 2012 | 06:48 PM
Car: 87 iroc
Engine: 410 sbc
Re: Speedhut Gauges
you have any pics installed..talk about bringing a thread back from the dead....but that's why we have the search capabilities.
Old May 20, 2012 | 07:34 PM
Car: 1984 Firebird
Axle/Gears: 4.10
Re: Speedhut Gauges
pics from my install are here https://www.thirdgen.org/forums/inte...sh-guages.html
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
