Pillar Gauge Cluster
Old Mar 18, 2009 | 06:56 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Well, first of I know how crappy our stock gauges are. They don't read hardly anything accurately, so I'm going to invest in some Cobalt Autometer gauges soon. Particularly the water temp, oil psi, and fuel psi gauges. I already have a little autozone oil psi gauge connected to the bottom of my dash, but it never sits the way I want it to and I usually end up bashing my knee against it.
So... I've been thinking of ordering the a-pillar gauge cluster and putting the gauges in there. My only concern is: does it look as good installed as the original pillar? I know the bottom gauge pod rubs against the dash pad, but I'm asking if the pillar looks flush and clean installed in place of the original a-pillar. Also, if I go with just 2 gauges instead of 3, does anyone make a full pillar with just 2 or is it just a little peace I basically have to stick onto the existing pillar?
I want as accurate readings as I can get, but I really want to keep a stock appearance so making a custom instrument panel in the dash is out of the question.
Old Mar 18, 2009 | 02:54 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Pillar Gauge Cluster
I love my full pillar pod. Ive had it for quite a few years now, and moved it from one car to another. It fits perfect and looks like it belongs. Most people wouldnt even know it was aftermarket. I think its WAY better than attaching gauges all over the place and under the dash.
Right now, Im just running 2 gauges in a 3 gauge pod. I sold my narrow band O2 sensor... So I got a snap in cover/blank to make the hole look better. Now I have a wideband O2 gauge to install... But it looks fine with the blank.
Here's a pic of how it looks currently with the blank installed.
And here's a couple during my build, when I still had 3 gauges in it. The bottom pod does rest on the dash...but its not a big deal.
Hope that helps ya with your decision... I say buy the 3 gauge pod that is made to fit our a-pillar. Put a blank in it... That way, if you decide to add another gauge, you're good to go. Or you could mount a shift light behind the blank. Or get a cheap gauge like a vac. gauge. Lots of options. If I wasnt going to have 3 gauges, Ide probably mount my shift light in the bottom spot behind a blank.
J.
Old Mar 18, 2009 | 05:07 PM
Car: '86 Trans Am
Engine: 305 H.O.
So it just goes in there the way the normal pillar does with no problems or gaps between the plastic and metal at all? Also, what gauges would you reccomend for a 305carb? Oil psi is a must for my cars, but I can't decide on the other two. Thinking Fuel Pressure and Water Temp.
Old Mar 18, 2009 | 05:13 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
I have done thsi to my T/A. mounted 2 gauge pods on the a pillar then fiberglassed them and then painted them. I have 4 gauges total.I can post some pics up if youd like so you can get an idea of what it looks like.
Old Mar 18, 2009 | 08:30 PM
Car: '86 Trans Am
Engine: 305 H.O.
That would be nice to see. Thanks.
Old Mar 18, 2009 | 10:10 PM
Car: 86 Trans AM
Well, it sort of fits over your existing a-pillar cover. I think the hardtop cars are alittle different... But either way, it fits perfect. It covers the ENTIRE a-pillar and attaches via push pin type things.
Its hard to tell its not all one piece unless the tops are out...and even then, if you didnt know what you were looking for you'd never notice any gaps or seams.
As for what gauges you should get...thats up to you. Ide say oil pressure and water temp are the most important "basic" gauges. Fuel pressure might be a good one...though I always think of them being more important on an EFI car. Like I said...you dont HAVE to fill the third spot right away.
J.
Old Mar 18, 2009 | 10:22 PM
Engine: Vortec 357
Ill get you some pics tommrow.
Old Mar 19, 2009 | 01:21 AM
Car: '86 Trans Am
Engine: 305 H.O.
Well, if I could get a full pillar with just 2 gauge pods, I'd get it. I just don't know exactly what 3rd gauge would be useful for a carb'd car. Oil psi and water temp I'm going to be getting so I can do away with this autozone gauge on my dash... it bugs me.
Old Mar 19, 2009 | 06:06 AM
Car: 86 Trans AM
I dont think there is a full pillar pod with only two guages. You will have to get one of the 2 gauge pods, and if you want it to look like it belongs, you'll have to fiberglass it into the a-pillar like it sounds like TADailyDriver did.
Personally I think 3+ looks good over there...and you can always fill the third spot up with a cheapie like a vacuum gauge. They are somewhat useful...Im running a vac gauge, fuel pressure, and wideband in my car. But, you gotta go with whats in your budget, what looks good to you, and what you think you can use best.
J.
Old Mar 19, 2009 | 12:30 PM
Engine: Vortec 357
J.
heres the link to my post i made when i did my gauges. Includes pics. I started with 1 2 gauge pod, then added another. Very easy to do. let me know what you think. I will get some better close up pics tonite. my stock water temp and oil psi dont work anymore but ill be fixing that soon.
https://www.thirdgen.org/forums/interior/487174-quaddruple-gauge-pod-88-a.html
Old Mar 19, 2009 | 02:21 PM
Car: 86 Trans AM
Yeah I remember seeing your set up awhile back. You did a nice job. I had a hard enough time coming up with 3 gauges to fill mine up let alone 4 haha.
J.
Old Mar 19, 2009 | 02:35 PM
Demon355's Avatar
Autometer Phantom A/F, Trans Temp and Oil pressure.
Old Mar 19, 2009 | 09:25 PM
tater7765's Avatar
Car: 87 camaro
Engine: 2.8L for now
Transmission: t5
Axle/Gears: stock for now
DyingYoung138- you can get a full pillar 2 pod from speed hut. i dont know how they look in our cars.
ghettocruiser- where did you get your pod from. i like the way i looks. i do have a hardtop so the top is going to be cover. how hard was it to get in place.
Old Mar 20, 2009 | 06:16 AM
Car: 86 Trans AM
My pod, as well as the two gauge pod that you mentioned, are both from Autometer. You can pick them up at any of the good online stores. Summit, speed hut looks good but I never used em, egauges.com, etc etc.
I thought I remembered the hardtop cars getting a different type of pod...one that covered more, or one that replaced the entire trim. That might have changed however.
Mine was really easy to install. I took my trim off, laid the pod in place so it matched up, attached it, and it was good to go. You gotta make some holes in the a-pillar trim to pass wires and hoses through. Atleast I had to.
I also recommend installing some type of quick disconnects on those gauge hook ups. Like for the wiring and hoses. Makes it easy if you ever have to remove the trim for something. Im going to re-do my wiring when I install my wideband.
No one will be disappointed with autometer's stuff. Ive been running there gauges and gauge pods for years, and both my jeeps as well as my car have guages and pods from them. Love em.
J.
Old Mar 22, 2009 | 07:56 PM
tattooadam's Avatar
Car: 91 Formula 350 WS6
Engine: 5.7
Axle/Gears: 323
So where can you get the pillar from?
Old Mar 22, 2009 | 11:53 PM
americanmuscle3's Avatar
Car: 83 z28
ive got a used 1 for a hard top car pm me for details
Old Mar 23, 2009 | 06:36 AM
Car: 86 Trans AM
Check the post right above yours.
Old Sep 22, 2009 | 02:41 AM
87-monte-ls's Avatar
where can i buy the snap in gauge cover/blank?
Old Sep 22, 2009 | 06:03 PM
Harwood's Avatar
Car: 1985 Pontiac Firebird
Engine: '93 LT1
Axle/Gears: 4:11
I've never wanted a pillar pod on my car 'till now. I guess I'd just seen too many poorly built and ones that didn't match the car correctly. Usually the same people who plug under dash lights into 3 prong cigarette lighter outlets. :S
Old Sep 23, 2009 | 05:59 AM
Car: 86 Trans AM
Here's where I got mine. Should be ok posting the link...I dont think any sponsers sell these things. If they do...I would like to know.
http://prosportgauges.com/52mm-switc...uge-blank.aspx
I painted the silver ring black since I have Phantom gauges. I also paid less at the time...looks like they went up about $1.
J.
Old Sep 23, 2009 | 07:38 AM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
Here's another couple of pictures of a triple pod in hard top.
It mounts flush over the existing plastic and from outside the car it's hard to tell it's been added in.
Old Mar 6, 2011 | 12:29 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
looks like the bottom gauge sits on the dash.. is that my imagination or what?
Old Mar 7, 2011 | 02:29 PM
MNformula350's Avatar
Old Mar 7, 2011 | 02:35 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i was gonna get a 2 gauge pod just for looks..probably get A/F and oil pressure
Old Mar 28, 2011 | 03:34 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i love the way these gauge pods and gauges look. found a guy on ebay that has amazing prices on autometer gauges. cant wait to get some and install.
Old Mar 28, 2011 | 03:42 PM
Demon355's Avatar
I have Ultra light 2 1/16 Boost and Trans temp for sale if need? Could use a Volt gauge for the same style.
Old Mar 28, 2011 | 06:12 PM
one92rs's Avatar
Car: SOLD!!!!!
Old Mar 31, 2011 | 03:10 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you could get a clock guage as your third guage.
Old Aug 25, 2016 | 12:43 AM
transamaster's Avatar
Car: 1989 Trans Am
Transmission: 700 R4
Where did you get speedo and rom gauges from? I like the style and want to put into my 89 trans am! Easy to put in?
J.
Old May 3, 2020 | 04:48 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Are the coolant temp gauges long enough to be routed to the pillar?
Old May 18, 2020 | 07:22 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Yes it is.
It’s more than long enough.
Oil, water, and fuel.
Old May 19, 2020 | 02:48 AM
Originally Posted by Z03Z28
Yes it is.
Those are nice gauges. What brand are they?
Old May 19, 2020 | 07:42 AM
Z03Z28's Avatar
Glow Shift
Old May 25, 2020 | 04:40 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Attachment 434546
Attachment 434547
Attachment 434548
J.
What gauge panel is that, in the dash. Looks like it keeps the factory turn signal indicators and SES light. Like the way it has the oval inset for the small gauges.
DR.K.
Boreen
Aug 18, 2013 05:52 PM
mb2hurley
Apr 3, 2013 10:57 AM
86Z
Aug 26, 2012 09:03 AM
Superjustin13
Nov 19, 2011 04:57 PM
