speedo not working help!
Old Apr 4, 2009 | 03:16 PM
JJx91camaro's Avatar
Car: 1991 chevy camaro rs
Engine: carbed 350 sbc
Transmission: th350
my mph on the gauges just stoped working today. it acted like it wanted to work then didnt...i think something got disconnected but cant find anything disconnected. plz help
Old Apr 4, 2009 | 03:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: speedo not working help!
What year, if its mechanical its most likely your spedo cable. A quick search can yield most answers to your problem. Good luck
Old Apr 4, 2009 | 03:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. If your car is a 91, as your name suggests, your speedo is electronic. The VSS on the tail shaft of the trans is often the culprit.
JamesC
Old Apr 4, 2009 | 03:34 PM
Transmission: th350
well it is a 91. v6. i took it to the shop to get the fuel pump changed, it was working then and always has been. get the car back from the shop and the mph gauge doesnt work but all the other gauges work. any pics or something for reference for me to fix this?....ive tried searching the site but cant seem to find anything
thnx
jj
Old Apr 4, 2009 | 03:42 PM
JamesC's Avatar
The VSS screws into the tail shaft of the trans, driver's side, in the same spot that a cable-driven speedo would.
JamesC
Old Apr 4, 2009 | 03:57 PM
Transmission: th350
JamesC
so its a screw in or is there a connector that snaps into it? cause i do see a connector hanging down there but i cannot reach it as i have no way of getting the car into the air
Old Apr 4, 2009 | 04:05 PM
JamesC's Avatar
A connector is involved.
JamesC
Old Apr 5, 2009 | 04:10 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
I expected to see a picture of a guy trying to remove a wedgie from his speedos in this thread.
Old Apr 8, 2009 | 11:50 AM
Transmission: th350
turns out it was a connector leading to the vss. thnx
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
