15 in subs
Old Sep 2, 2009 | 12:31 AM
83z28glover's Avatar
Car: 1983 Z28 Camaro
Transmission: 5 Speed Manual
15 in subs
Im new to the forum, i just got my 83 z28 today and i cant figure out how im going to fit my 2 15" kickers in there, if anyone could help me out I would appricate it.
Old Sep 2, 2009 | 12:44 AM
Stephen's Avatar
Car: 87 GTA
Re: 15 in subs
Your gonna hafta build your own box to fit in the rear well, with an angled top, wide enough to fit your 15" sub in to.
Old Sep 2, 2009 | 01:58 AM
Re: 15 in subs
Do you have plans for that? Sounds like quite the job lol. Thanks for the reply.
Old Sep 2, 2009 | 02:05 AM
Stephen's Avatar
Car: 87 GTA
Re: 15 in subs
This will get you started......
https://www.thirdgen.org/subwoofer
And.....
https://www.thirdgen.org/forums/car-...l-sub-box.html
Use the feature here on TGO & you'll find TONS of info. Not much chance of you not finding your answer already here, short of things like new items or technologies.
TGO has been here, in this latest creation, for about 13 yrs. It is much older, but had much less info & wasn't kept up very well, by it's owner. So Thirdgen.Org was created.
Old Oct 5, 2009 | 09:54 PM
Irocmatt83's Avatar
Re: 15 in subs
Youp gotta build your own box. But at the end of the day it will be cheaper than having a custom box made at your local shop. Not mention not alot of people put 15" subs in camaro's. Good luck
Old Oct 5, 2009 | 11:07 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Re: 15 in subs
This was a buddy of mine who put 2 18s in his bird. It will definitely work but YOU will need to get creative with the box and placement of the subs.
http://www.cardomain.com/ride/433125/5
Old Oct 6, 2009 | 04:18 AM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: 15 in subs
http://cgi.ebay.com/CAMARO-FIREBIRD-...d=p3286.c0.m14
tons of these on ebay. It might not have enough airspace for your kickers though. although it says for 84-92, I am pretty sure it really fits from 82-92
Old Oct 6, 2009 | 07:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 15 in subs
First, figure out how much air you need for the Kickers.
You may discover that you don't have enough.
The ebay box only gives 1.8 cu.ft. per side.
You're not going to get much more than that.
Make sure to Dynamat....a lot.
Old Oct 9, 2009 | 04:03 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: 15 in subs
this may be over-simplifying things here but couldn't you just get a 12" speaker box and cut the holes bigger to fit 15" subs?
Old Oct 9, 2009 | 04:10 PM
Re: 15 in subs
Not really. 15s need more airspace than 12s therefore the box needs to be bigger. most of the 12 boxes arent big enough to even shoehorn the 15s in.
Old Oct 23, 2010 | 11:19 PM
1983CamaroZ-28's Avatar
Car: 1983 Camaro Z-28
Re: 15 in subs
Hey im pretty much in the same situation here.I already have 2 Cervin Vega's 12's on a custom made box for Camaros, So I was just thinking of making the holes bigger & putting My 2 15" Kickers but it does seem like it isnt enough room in height, It looks like the bottom Magnet of the speaker is going to fit!!!Name:  207.jpg
Size:  36.5 KBName:  newestshit0062.jpg
Size:  43.0 KBName:  newestshit0032.jpg
Size:  50.6 KBName:  newestshit0042.jpg
Old Oct 23, 2010 | 11:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 15 in subs
Not 15s, but this is how i mounted mine.12in Cerwin Vegas.
Old Oct 23, 2010 | 11:44 PM
Stephen's Avatar
Car: 87 GTA
Re: 15 in subs
Cut out the area between the 2 12" holes. Mount a new board on op of the box, leaving just the amount needed for the 15" to fit, cut 2 15" holes closer together so that the magnets don't hit those 2 "steps" inside and VOILA! Your 15"s now "magically" in a 12" speaker box.
Old Nov 14, 2011 | 06:43 PM
Iroc-Z Tone's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
Re: 15 in subs
is that just a baffle board? if so how do your 12s sound with just free air space?
Old Nov 14, 2011 | 07:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: 15 in subs
Its a lid, like the OEM piece, made from particle wood.Didnt want to cut holes in my OE lid.Those are vintage free air subs, sound great, more than enough bass.
Old Nov 14, 2011 | 09:05 PM
Engine: 350 5.7 TPI
Re: 15 in subs
oh okay, I have a pair of Orion H2 15.2 subs & im planning on making a custom enclosure this weekend but I liked your idea. It looks simple so I will try that this weekend & see how mine sounds.
Old Nov 18, 2011 | 08:43 AM
91ORANGEZ28's Avatar
Car: 1985 Z28/ IROC-Z
Engine: 5.0 TPI
Transmission: T-56 Magnum F
Re: 15 in subs
I have a box for dual 15s near kansas city. Its in real good shape i removed it the day i bought my car dont want it.
Old Nov 18, 2011 | 09:24 AM
Engine: 5.0 TPI
Re: 15 in subs
Very similar to this one
Old Nov 18, 2011 | 01:49 PM
Engine: 350 5.7 TPI
Re: 15 in subs
can you give me the measurements & dimensions of your sub enclosure for 2 15s? I'm going to try to build one on my own this weekend.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
