speedometer not reading correctly
Old Sep 14, 2009 | 07:29 PM
polaris91's Avatar
Car: 88 camaro z28
im not sure whats going on with it but it will read about 15-20 mph when im actualy doing about 60-70 mph does anyone know what could be going on the only thing that i have done around the guages is the needle fell off and i glued it back on could that be why? if not what could it be? thanks
Old Sep 14, 2009 | 07:43 PM
polaris91's Avatar
Car: 88 camaro z28
Re: speedometer not reading correctly
also could it be that it isnt the correct speedometer for the car? it is a 115 mph speedo the car is a 88 camaro the dash says its a z28 but the side badges on the ground effects say its an rs the kid i bought it from told me the side ground effects were replaced because they were broke so im not sure if it should have a 115 speedo or possibly its supposed to have a 145?
Old Sep 14, 2009 | 08:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by polaris91
...the only thing that i have done around the guages is the needle fell off and i glued it back on could that be why? if not what could it be?
Yes.
https://www.thirdgen.org/forums/inte...eedo-woes.html
A 145 will swap in if you should so choose.
JamesC
Old Sep 14, 2009 | 09:32 PM
polaris91's Avatar
Car: 88 camaro z28
will one swap in with no other modifications?
which one of those in your post would be the most likely for my problem?
thanks
Old Sep 15, 2009 | 06:31 AM
JamesC's Avatar
thanks
No other modifications are necessary. To avoid any possible electrical gremlins, I swap in the speedo head only.
Hard to say.
JamesC
Old Sep 15, 2009 | 01:42 PM
polaris91's Avatar
Car: 88 camaro z28
as in un bolt it from the plastic cluster and replace?
Old Sep 15, 2009 | 02:53 PM
JamesC's Avatar
Yes. The following link will provide a bit of a how-to:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Sep 15, 2009 | 07:24 PM
polaris91's Avatar
Car: 88 camaro z28
ok cool thanks im going to try to find a 145 speedo if i cant i guess ill have to settle for a 110 do you know of any? i dont have too much money to spend as i am a full time highschool student
Old Sep 15, 2009 | 09:44 PM
JamesC's Avatar
I have a 145 speedo head (not the cluster) that was refurbished at a GM facility ($80), but in my car it always jumped three or four miles an hour starting around 60. Should you be interested, I'd take $25 shipped. If not, you might consider advertising for either the 145 or the 110 in the site's classifieds.
JamesC
Old Sep 17, 2009 | 02:20 PM
polaris91's Avatar
Car: 88 camaro z28
lemme seeif i can find a fully functioning one first haha and ill let you know
toones
Jan 6, 2016 06:00 PM
AUZ28
Oct 12, 2015 08:40 AM
Regal105
Aug 23, 2015 03:45 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
