gta console in my 85 iroc
Old Dec 31, 2009 | 12:12 AM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
would it be easier to go for a 4th gen console or would the gta stuff bolt up?
basically are they interchangeable?
Old Dec 31, 2009 | 12:32 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: gta console in my 85 iroc
what are ypu going for with it?
Old Dec 31, 2009 | 12:34 AM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
The GTA console will fit, but the console was designed for use with a radio pod. The console in your Camaro is very different than the GTA console in many ways. You'd need to either hack up your console to leave the radio portion attached to your dash (which always looks terrible) or you'd have to get a Firebird radio pod and try to make it work.
Old Dec 31, 2009 | 12:45 AM
ShMaCk2004's Avatar
or do what i did and get a 4th gen firebird dash and console
Old Dec 31, 2009 | 01:43 AM
Engine: 305TPI
Well you could do that as well.
Old Dec 31, 2009 | 07:20 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
how easy is it to put in a 4th gen console?
Old Dec 31, 2009 | 08:24 PM
Drew's Avatar
Or you could stick with the stock Camaro console, since it matches the rest of the stock interior and doesn't warp and fall apart with age.
Old Jan 1, 2010 | 01:51 PM
Engine: 305TPI
That would be my advice. That's one thing I love about the 1982 to 1984 Firebirds. They use basically the same console, and I've seen junkyard cars that are in extremely rough condition with excellent center consoles. In contrast there are many otherwise pristine or perfect Firebird/Trans Ams with center consoles that are in very rough shape.
Old Jan 1, 2010 | 02:06 PM
ShMaCk2004's Avatar
not that hard really. with a bit of you will find everything you will ever need to know about it
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
TheJoeY88
Aug 13, 2015 06:51 PM
mustangman65_79
Aug 11, 2015 03:17 PM
