4th Gen cluster into 3rd gen - does v6 or v8 matter?
Old Jan 21, 2010 | 05:36 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hey guys,
sorry for not searching the threads properly, but its a time critical question as i have to buy the cluster in the next hour or so, but if I go to use a 4th gen firebird cluster into my car, can I use any 93-97 cluster and re-wire into mine, or does it need to be a specific type? eg V8 cluster from auto etc?
And if so, can they be re-programmed? and if so how is it done?
I'm in australia so i probably wouldnt be able to get anyone here to do it.
Old Jan 22, 2010 | 05:54 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 4th Gen cluster into 3rd gen - does v6 or v8 matter?
Trans does not matter , if you get a V8 cluster your tach will be off if your engine is a V6 and vice versa.
Old Jan 22, 2010 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unfamiliar with Birds, but will a fourthgen cluster fit a thirdgen dash without major modification? This would be the case with a Camaro.
JamesC
Old Jan 22, 2010 | 03:53 PM
evilstuie's Avatar
Is there anyway to recalibrate for v8?
Anything will fit if you make it.
3rd-4th gen camaros are straight swap i think.
3rd-4th T/A are not, but i'm making a custom dash anyway and the 4th gen is just a lot neater and smaller.
Old Jan 22, 2010 | 03:59 PM
JamesC's Avatar
True.
Even a thirdgen 90-92 Camaro cluster won't swap into an 82-89 without major modification. A 93+ certainly won't unless "you make it."
Sounds interesting.
JamesC
Old Jan 22, 2010 | 04:02 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Yes but really why bother? V8 clusters are as common as dog doo.
Old Jan 22, 2010 | 07:56 PM
evilstuie's Avatar
because i found a v6 cluster for $80AUD including shipping in perfect condition on ebay, and the cheapest v8 one i can find is $150AUD and then another $110 shipping.
They might be common as over there, but no-one puts them up on ebay.
Old Jan 22, 2010 | 08:29 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
thats too much
www.lkqonline.com i got my HARD to find cluster 97Lt1 Z28 cluster for 65.00
Old Jan 30, 2010 | 07:01 PM
evilstuie's Avatar
lqk don't do international shipping.
Now I'm back where i started
Old Oct 25, 2010 | 08:28 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I'm working on a recalibration fix for the 4th Gen V6 gauges. LT1 gauge clusters aren't freely available in salvage yards everywhere, and the prices for them on Ebay are getting ridiculous. Being able to use a V6 cluster would simplify things greatly, as these are much more common in the yards.
Old Oct 25, 2010 | 08:47 PM
evilstuie's Avatar
if i'm upgrading to an 0411 PCM to run sequential injection, can i then run one of the newer v8 gauges? or it won't work that way?
Old Oct 25, 2010 | 08:52 PM
If it's the 98 - up gauge cluster and ECM/PCM, with all the correct sensors, it should work, as the 98 - up was controlled by the computer. I'm not sure on this though, I'm working on the 93-97 non-computer controlled gauge circuitry only.
F-body-fan
May 4, 2026 09:42 AM
junior419
Apr 7, 2025 11:35 AM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
Diabolical
Apr 7, 2003 12:50 AM
