Does anyone have a problem with the clocks?
Old Mar 17, 2010 | 06:59 PM
vengetta82's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
every time i set my clocks, they reset after the car shuts down... and now my digital is reading in military time
Old Mar 17, 2010 | 07:17 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Does anyone have a problem with the clocks?
Just your clock, or are radio presets getting reset too? Sounds like its loosing power entirely between starts. Maybe an alternator issue?
Old Mar 17, 2010 | 07:22 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Check to see if the yellow wire that runs to the radio is getting power with the key, do the same with the red wire.
Old Mar 17, 2010 | 07:59 PM
vengetta82's Avatar
Engine: LG4
I'll set it, both the analog and the digital, and get in the car and it will read a random time. My radio is just fried [i think] because it would tune with the regular tune ****, but when i used the preset buttons, it wont use the tune ****, so now its stuck on static. Anywho, I'll try what u guys said and see if it works
Old Mar 18, 2010 | 07:27 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
this happened to me before, it resets the clock and the presets, your battery is going on you. recharge it w/ the alternator for a bit. or it might be the alternator itself.
Old Mar 18, 2010 | 07:23 PM
vengetta82's Avatar
Engine: LG4
well, i dont mean to be rude, but i drive it all the time, and since the alternator sends extra power to the battery, and this is happening after i shut the car off, i really dont see how it could be battery/alternator, especially since i had it checked and the mechanic said the alternator was fine. im thinking its the wiring of the clocks. but thanks for the idea, slash
Old Mar 18, 2010 | 08:37 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
sounds like the constant 12V isnt getting power, Id check to see if your constant 12V for the radio is getting power or not, if its resetting everytime you start the car it sounds like you have the constant 12V and ignition 12V tied into the same wire from the radio.
Old Mar 19, 2010 | 07:37 AM
Slash's Avatar
I Based my answer on your question "Does anyone have a problem with the clocks?"and the information that was given, when you have a problem it's a good thing to state everything "Daily driver/Checked by mechanic and ruled out alternator" ect, it rules out more possibilities and gets you closer to the true answer. -
Old Mar 19, 2010 | 05:35 PM
vengetta82's Avatar
Engine: LG4
okay. sorry slash
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
