speedometer
Old Apr 1, 2010 | 05:17 PM
magna's Avatar
Car: 1992 Camaro RS
Engine: TBI 305
Transmission: 5 Speed
speedometer
my 92 rs speedometer is completely inop. also the RPM gauge is working but incorrectly. I have a repair manuel that says the speedometer is plugged into the cruise control transducer ( cause its a standard ). I see the pic in the manual and i see no cruise control transducer or any signs of there being one under the hood. I do have cruise control and no it doesnt work but the whole unit is there and nothing is missing from it that I can tell. I figured that it was a cable that plugged into the tranny, but I see nothing but electrical connections to the tranny not cables. can anyone help me diagnose any of these issues so that I can get my speedo working right. I just want to know for sure where it plugs into so i can diagnose it. If its electrical I think it is the connector by the tail housing of the tranny but just want to be sure. Also I think the rpm gauge plugs into distributer and if all is well wouldnt it be the controller inside the cap that is probably the problem? thanks for the help in advance!
Old Apr 1, 2010 | 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer
Welcome to TGO. The transducer is long gone, so forget that. Your 92 speedo is electric. Often the problem is the VSS located on the tail shaft of the trans. Since the problem is fairly common, a search, which is always a good idea on TGO, is in order.
JamesC
Old Jun 13, 2010 | 04:51 PM
magna's Avatar
Car: 1992 Camaro RS
Engine: TBI 305
Re: speedometer
Well after looking around on this site i concluded that I may be able to take the VSS apart and fix it by cleaning it out. Well I took the VSS out of my tranny (didnt know that it was gonna pour out tranny fluid!) and realized that it is a solid state plastic unit. So after cleaning up a big mess and putting the VSS back in I thought that I was just gonna have to replace the VSS all together. Well I started to wonder if there was a possiblity that the vss was even the problem at all. So I took my instrument cluster out and looked at the little circuit board that the speedo plugs into and realized the real problem there. The board had serveral components on it that were fried completely. So now at least I know what I need to do to fix speedo. This repair should also fix my inop cruise control correct? My RPM gauge is still not working correctly it reads way too high and I have seen on here that is not a uncommon issue.
Old Jun 13, 2010 | 06:13 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: speedometer
Did these gauges ever work correctly since you've owned it? Just wondering if PO swapped in a V6 cluster or something. Just curious, I also have a 92 RS with 5.0 and 5sp and an extra cluster if that is your problem. Sorry don't know much of anything except how to remove and reinstall. Good luck to you How much higher is the tach reading anyway and where are the redline markings on it?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
