Speedometer calibration ???
Old Apr 23, 2010 | 04:49 PM
SEIKI's Avatar
Car: 85 iroc original owner 24,000 miles
Engine: 305 tpi
I have a mechanical speedometer from a 89 IROC that I am trying to calibrate. It's reading about 11 mph slow, It appears that there is a window on the back of the housing that you use as a timing window. There are some counter weights in there also. Am I on the right track? Any suggestions would be appreciated.
Thank's
Old Apr 23, 2010 | 04:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer calibration ???
You might take a peek at the following info in advance of attempting anything too drastic:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Apr 23, 2010 | 05:24 PM
SEIKI's Avatar
Engine: 305 tpi
The speedometer worked fine until my son removed the needle. I think it's just a matter of getting the counter weights in time with the needle.
Old Apr 23, 2010 | 07:48 PM
JamesC's Avatar
You might have better luck experimenting with needle placement.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
