anyone ever put guages in these locations?
Old Jun 15, 2010 | 03:26 PM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
i need to add water temp and oil pressure gauges, and i didnt really want to use the a pillar holder. also thought about mounting them above the hvac controller.
Old Jun 15, 2010 | 03:43 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: anyone ever put guages in these locations?
I'm sure someone has. The A-pillar position makes the most sense to me as it not only is a good place for the gauges but it makes undoing the installation easier if you ever decide to go back to a more stock look.
Old Jun 15, 2010 | 04:27 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I have oil pressure, temp, and vacuum gauges mounted to the underside of the center dash vents. Right above the HVAC/Radio. If you want I can grab a pic tonight when I get home and post it up.
Old Jun 16, 2010 | 07:40 AM
Axle/Gears: 3.08
if you could that would be great
Old Jun 16, 2010 | 08:58 AM
one92rs's Avatar
Car: SOLD!!!!!
i mounted mine here. it is an autometer evo pod.
Old Jun 16, 2010 | 09:24 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
The temp and oil gauges are just cheapies from Harbor Freight, but they do the job. The Vac gauge is just a temporary one I stole off my handheld vacuum pump till I can find one I like.
Attached Thumbnails anyone ever put guages in these locations?-photo0144.jpg   anyone ever put guages in these locations?-photo0145.jpg   anyone ever put guages in these locations?-photo0148.jpg
Old Jun 17, 2010 | 03:54 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
The evo pod looks good! It blends in nicely with the rest of the dash.
Old Jun 17, 2010 | 06:32 AM
AC's Avatar
AC
Car: Used to drive a camaro
I took the DIY route using ABS panels
https://www.thirdgen.org/forums/body...guage-pod.html
Ghettobird52
Jul 5, 2024 11:18 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
355sbcTPI
Aug 19, 2015 04:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
