Solve my stupid trunk problem
Old Jun 30, 2010 | 02:23 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
Okay, I need to get my trunk open, but the button isnt working anymore. The key hole on the trunk has never worked either. Does anyone have a clever way to open the trunk? It has the electric trunk closer thingy, and it's not making any sound when the button is pressed.
Already checked the trunk fuse.
Old Jun 30, 2010 | 02:37 PM
Nasphreak29's Avatar
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
Re: Solve my stupid trunk problem
If you wanna get it open so you can fix it? my advice is to climb through the hatch and pop it open with a screwdriver. but be warned...you may not be able to reshut it if you dont fix it.
Old Jun 30, 2010 | 04:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My 1st attempt would be to take the center console top off and see about the switch - maybe simply applying 12v or ground to one wire or the other will pop it for you - maybe the switch is just bad.
Climbing in over the rear seats is hard to do - the rear plastic is held in place with screws on the top, which is not accessible since the hatch is closed. You'd have to carefully go up from the bottom and try to pop it without breaking the rear plastic.
Old Jun 30, 2010 | 07:36 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Some people have been able to remove the rear hatch light from the back panel, access the back of the latch and open with a screwdriver. It depends on whether you have the light and then where it's located. Good luck
Old Jun 30, 2010 | 07:41 PM
Drew's Avatar
Locate the hatch release relay, jump 12v+ to the black wire. If that doesn't do it, order a new trunk lock at the dealer, and grab a drill with a 3/8" or larger bit and start drilling until you can remove the lock tumblers, then turn the lock with a large flat blade screwdriver.
Old Jul 7, 2010 | 03:18 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Ok thanks for the replies. I have the rear light, which i pried off, and I can see the trunk hold mechanism. I am trying to just pop it with a screwdriver, but I cant seem get the right movement. Could anyone describe what to do with the screwdriver to get it open? Trying not to break anything. Thanks.
On an unrelated note, is it possible to replace the electronic, moves up and down trunk release, with a stationary latch?
Old Jul 7, 2010 | 03:32 PM
FlamingPhoenix's Avatar
Car: '85 Trans Am WS6
Engine: L69 H.O. 305
unscrew the hatch light (which it sounds like you've already done), now looking into the hole you will see a plate with a slot in it. All I had to do was insert a flathead screwdriver into said slot and twist counterclockwise and the hatch popped. IIRC it was only like a 1/4-1/8 of a turn to release the hatch.
Old Jul 7, 2010 | 05:13 PM
my82roc's Avatar
Car: 89 Iroc Convertible
If it wont pop with a screwdriver then try and pull on the cable that runs from the hatch pulldown to the lock cylinder.it will be on the left hand side thru the rear hatch panel courtesy light hole.Stick you finger in there and tug on it.
Old Jul 8, 2010 | 04:42 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
ok, i checked the fuse, its fine. Just to check, the wire going to the trunk mechanism is under the center console? And running 12V into that wire will make the hatch pop, if the mechanism is still functional. Anyone know what color the wire is?
Old Jul 13, 2010 | 04:31 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Got it open. I was able to crawl back over the seat into the trunk, and undo the four nuts which hold on the upper latch piece. It was tight and hot, but i got it open. Now I just have to figure out which part is bad.
Old Jul 13, 2010 | 04:48 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You should of lowered the stupid rear seat first. But I guess stupid is stupid when you call your car that. Lets see how you
fix the stupid hatch release???
Old Oct 8, 2010 | 03:28 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Thanks for the absolutely unhelpful reply. Just found which part was bad, it was the fuse... Took me until a week ago to realize nothing in the cab was working... Anyway, it works now. Doesnt work correctly, but it never has.
Old Oct 8, 2010 | 03:33 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
dude, wtf was with that reply? How do you know he didnt lower it?
Old Jun 12, 2012 | 09:30 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
if its the pulldown hatch you can try smacking the motor. If that works, lube the **** out of everything that moves!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
