Removing overhead console in favor of the stand alone dome light....?
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am beginning to really hate the overhead console in my 91Z. It is always in the way and it doesn't serve much purpose for me.
If I remove it, can I just install the stand alone dome light/map light setup? Do I need any add'l mounts or will the dome light mount to my existing roof structure?
Transmission: Pro-built 700R4
Re: Removing overhead console in favor of the stand alone dome light....?
I think you'll have holes in your headliner from the mounting points of the overhead console. If you need any of the regular dome light parts, let me know. I just removed them from my '91 GTA in favor of an overhead console.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, you will have holes in the headliner from the overhead console mounts. But you can remove it, and the stand alone light will hold up the headliner.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll find what the holes may look like in the following link:
https://www.thirdgen.org/step-by-ste...e-installation
JamesC
JamesC
Axle/Gears: 3.23:1
Does the dome light have the map lights in it? I may be interested in yours if its complete.
The stock dome lights don't have a map light. Its just the one dome light and its housing. No map light.
Car: 1992 RS
Engine: Carbed 350
There are dome lights with map lights, not sure if they were a 3rd gen option, but I had one at one time - a perfect fit. I see them on ebay all the time, just search "82 92 camaro dome" and you should see them.
Car: 89 Iroc Convertible
Some 3rd gens came with the deluxe dome light which had 2 maplights on it
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
@Dante, I have the dome with the 2 map lights,I might be interested in exchanging for your console screws
Interesting. I learn something new all the time on this website. I've never seen a dome light with map lights in a thirdgen.
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
JamesC
JamesC
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
Car: 87 GTA
Facing backwards. Just behind the map pocket & just in front of the dome light. You probably have a rectangular opening. If you don't, then the map light is in there. Push it in, to get it to pop out.
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
thanx guys i always wondered what that rectangle was for....well after prying it out with a good old screw driver i finally got it out its awesome!!!!but unfortunately i think the previous original owner didnt know about n never changed the batteries so one exploded, im thinking about trying o clean it up and putting in new batteries, but i doubt itll work, has anyone swaped an l.e.d. in there? just wat im thinking about i think this thing is so cool.
the good
the BAD
the good
the BAD
Modern, I have set for sale in the classifieds, if you can't strike a deal with Dante.
avilla, the flash light shown above should clean up. Afterward, use a bit of dialectic grease to keep it from corroding.
The following is a link to install LED's in the overhead:
https://www.thirdgen.org/forums/inte...-overhead.html
JamesC
JamesC
86CamaroDan
Sep 29, 2015 10:08 PM
