cant get speedo out
Old Oct 16, 2010 | 05:14 PM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
cant get speedo out
im pulling the dash on my camaro and i have everything out except the speedo and that seems to be holding me up. if anyone can tell me how to get the speedo out or has another idea of what might be stuck please let me know.
Old Oct 16, 2010 | 05:16 PM
Drew's Avatar
Re: cant get speedo out
Did you disconnect the speedo cable? There's a black steel clip that snaps on the cable where it meets the back of the cluster. Press the tab on the clip towards the cluster and it'll release.
Old Oct 16, 2010 | 05:22 PM
mdihotmale's Avatar
Car: 1989 irocz,87irocz,05 tacoma trd
Engine: 5.7's,5.0.4.0
Transmission: a4, an sixspeed
i found it alot easyer to take the two bolts on the steering coloum an drop it down so it be alot easyer working on replacing speedo an such
Old Oct 16, 2010 | 05:23 PM
jfroh1992's Avatar
Axle/Gears: stock
i havent been able to get my hand back there to reach it
Old Oct 16, 2010 | 05:35 PM
Drew's Avatar
You probably won't be able to get back there with a hand... Use a long screwdriver to press the tab.
Old Oct 16, 2010 | 05:59 PM
jfroh1992's Avatar
Axle/Gears: stock
ok i will have to try that. it wont be help up on the center counsel at all will it
Old Oct 16, 2010 | 07:48 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've got a crappy pic of what it looks like. If you can peek back there and see the position of the clip, you can then use a screwdriver to hold it down while you pull it out. Make sure there's not any tension on it (or even push the cluster in a little) when you depress the clip or it probably won't release.
Old Oct 17, 2010 | 04:27 PM
jfroh1992's Avatar
Axle/Gears: stock
i was able to get at it with the dash hanging down alittle while laying under it with my arm around to the top pulling on the cable.
Old Oct 22, 2010 | 11:57 AM
davemel3nzc's Avatar
Just pulled one from an 86 IROC last night. Drop the steering column, take the frame clip that hold the speedometer cable under the hood down by the exaust manifold off. Then you can push extra cable through the firewall so that you can easily reach the clip on the back of the speedometer.
Old Jul 8, 2012 | 08:17 PM
JDud's Avatar
This is what got it done for me, thanks for the info!
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
