shifter knob,how to remove?
Old Oct 20, 2010 | 09:40 PM
jdracing's Avatar
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
shifter ****,how to remove?
one of my camaros shifter **** is busted and was wondering
if there was a special trick to removing?
i can't find a allen screw,or get it to twist off.
thanks for the help,
jd
Old Oct 20, 2010 | 09:55 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: shifter ****,how to remove?
Lefty loosey. The **** has some type of threadlocker on it, so you have to twist like hell to crack it loose.
Old Oct 20, 2010 | 10:02 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Our. " T " shifter handle has a staple-looking clip.
Set the park brake, put in Neutral.
Look at the dashboard side of the shifter handle for the small
holes. Push thru the holes with something like a screwdriver
from an eyeglasses kit a lil at a time, & look at the palm
side for the " staple " flat end coming out, then pull it out
with needle nose pliers. Try not to lose it!! Lil buggers are a
pain to look for if it falls between the console & seat!
Old Oct 21, 2010 | 01:34 AM
jdracing's Avatar
lefty loosey?...you are saying it's left hand thread?
if so,would never have even given that a thought.
it makes sense though if you were speed shifting
and the shifter ball came loose?
jd
Old Oct 21, 2010 | 07:09 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
If you "twist like hell" before you remove that staple , your going to be in a world of hurt.
Old Oct 21, 2010 | 01:08 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Automatic or standard transmission?
YEAR?
If its a stick with a stock ball head it should just unscrew.
If its a automatic with the leather covered ball head it will
either depending on year have a staple in the front lower part
of the ball OR you have to remove the release cap on top of
the ball and take out the snap ring then pull it off.
My 84 has the snap ring and no staple..................
Old Nov 11, 2010 | 02:39 AM
IROC 85's Avatar
Car: 1985 IROC-Z, Black and Grey
Engine: 305, TPI
Transmission: 700 R4
Please for the love of GOD, tell me you did not snap that retention clip! Auto's have retention clips for obvious reasons, if it's stick just twist it like your opening a door ****(leftee loosee). If it's an auto, look above cause TTOPHAVOC is spot on. Take your time and get this one right. Good luck
Old Mar 13, 2012 | 08:13 PM
Cebas(13)'s Avatar
Car: 1988 Camaro
Engine: 2.8 V6
i dont know if anyone posts on here ne more but umm got an 88 camaro and its an auto is it a staple or is it a clip? it has the piece u push and turn to release the spring
Old Jun 5, 2013 | 11:42 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
Transmission: Automatic
mine is an automatic shift gear, i need to remove the **** so i can replace another position indicator and i dont want to mess it up, mine has a little push in button to be able to shift to gears. help please
Old Jun 6, 2013 | 04:12 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
of the ball.
If it has the staple............ Pull the staple and pull it off.
IF NOT....... you have to remove the release cap on top of
Old Jun 6, 2013 | 05:40 PM
FinallyGotMyZ's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 305 5.0 L TPI
On a side note, where can you purchase the position indicator? After replacing the illumination bulb, I noticed that my gear position indicator is missing. Any help?
Old Jun 6, 2013 | 08:36 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Only the 88-92 had the shift indicator needle!
Your 86 does NOT have one.....................
Old Jun 6, 2013 | 11:58 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
sonjaab, thank you!!!
GotmyZ, i've been going to the junk yard to get my parts, sometimes i'm lucky and other times nope. If i can't find anything there then i try googling parts. If that doesn't work well then i ask in here, lol. Its not hard looking for parts but its hard being lucky to find them.
Old Jun 7, 2013 | 12:42 AM
Wow, thanks. I just assumed the gear indicator was there, learn something every day...
Old Jun 7, 2013 | 08:08 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Guys............If you looking for certain odd parts and having no
luck yard searching for your cars check out www.thirdgenranch.com
He has almost anything! Mostly used stuff but reasonable prices and quick service!
If you don't see it listed there send a e-mail and ask.
Thats where I got some oddball items I needed for my Z.
Old Aug 2, 2013 | 04:23 PM
hooptie's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI (For Now)
Classic Industries has a catalog that is strictly for Camaro. Google them, order the catalog. There isnt much that youd need that they dont have. Been rebuilding my 92 mostly from that catalog...
Old Oct 17, 2013 | 01:04 PM
Len Lencioni's Avatar
once you get staple out - then what pull up or twist off? Mine is a 91 RS.
Old Oct 17, 2013 | 02:15 PM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
Pull staple and lift straight up.
Old Oct 18, 2013 | 06:01 AM
Thanks! it worked perfect and slide right off.
You have any tips on the temperature control unit?
Old Oct 18, 2013 | 08:03 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
jd
on my 86 Camaro ,you first pull the button off then there a snap ring waaaayy down in there. but mines a auto
Old Nov 8, 2013 | 04:36 PM
IROCA90's Avatar
Car: 1990 Camaro Iroc Z28 G92
Engine: 5.7L TPI
of the ball.
i have a 90 Camaro, the mechanic that worked on my car left it that way. The release cap came off and i can't figure out how to put it back. Also, it's letting me change gears without applying the brakes.
Old Nov 9, 2013 | 10:54 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The release cap just friction fits in the hole in the top of the shifter.
I can assume the 90 cars DO NOT have the "brake to shift" interlock so
you don't need to press the brake pedal to shift out of park.
Yes, you should have to push the release button down to shift out of
Park. If u are able to shift out of park without pushing the button down
then the "mechanic" screwed something up in the shifter release.
Old Aug 8, 2014 | 06:07 PM
Bigboy29's Avatar
How do you take the shifter **** off I have a 91 chevy truck
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
