modify speedometer
Old Feb 24, 2011 | 05:41 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
modify speedometer
I have an 85mph speedometer and it's not cutting it going to work... grin! has anyone internally changed their speedometer and then added a new face plate to read 145 or even 200?
hope I'm not asking a question already discussed but couldn't find it by searching
Old Feb 24, 2011 | 05:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: modify speedometer
Originally Posted by scooter500
I have an 85mph speedometer and it's not cutting it going to work... grin! has anyone internally changed their speedometer and then added a new face plate to read 145....
Not that I know of. Wouldn't simply swapping in an OE 145 speedo head be easier?
JamesC
Old Feb 25, 2011 | 07:54 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Today I found out you're right - that swapping would be easier. By odd co-incidence a friend stopped by work today. I asked him and he explained his experience w/older speedos on mid-60's fords (guess it's the same principle). Anyway he said a magnet at the end of the speedometer cable spins inside a coiled spring that has a pointer attached to the end of the coiled spring metal. As speed of the cables nncreases the magnet circles faster and that pulls the coiled causing the pointer to show faster on the gauge. he said any adjustment would need to be very slight. The thought of trying to make a fine adjustment without any specs makes this project idea super impractical for me, so I'd be much better off buying one instead.
Old May 17, 2011 | 09:15 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I am running into the same problem I'm tired of seeing the needle smack the barrier at 85mph and learning what speed im at by checking the tach while going past a police radar stand =P. I thought the faceplates had the same amount of spacing in them for both the 85 and 145 so to interchange them would be fine. but i could be very wrong on that, does anyone know fore sure?
Old May 18, 2011 | 07:44 AM
JamesC's Avatar
Can't swap faceplates and expect the speedo to read correctly (a search should turn up a ton of info). Swapping the speedo head for the one of your choice is the best bet--I started with an 85, went to a 110, and finally a 145.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
