Corbeau A4 racing seat?
Old Jun 18, 2011 | 12:03 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
from hawks:
The dynamic A4 is the perfect application for tight spaces and minimal headroom applications. Standard features include: high-density injection molded foam, ergonomical design, harness belt capability, integrated shoulder, kidney and thigh support, leatherette high wear patches, and a fully adjustable seat back with a flip forward fingertip controlled lever for rear access. The A4 is extra aggressive in the kidney area and will fit up to a 36" waist.
questions:
are these good racing seats?
good for road racing applications?
pics of these installed?
http://www.hawksthirdgenparts.com/co...ellowblue.aspx
Old Jun 18, 2011 | 12:55 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: Corbeau A4 racing seat?
Wow i really like the look of that, i might get me a pair some day!
Old Jun 18, 2011 | 10:39 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
yeah i love the way they look..not gonna get em in blue though..
Old Jun 18, 2011 | 11:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got the Forza fixed back seats in my car. They feel great. Really hug me and hold me still in turns and feels good at the drag strip too.
A4's are similar size so they will fit good.
Old Jun 18, 2011 | 07:55 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
alright cool they look good!
whats the advantages for having a fixed back?
Old Jun 18, 2011 | 11:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
idk, i dont have rear seats so i dont need a reclining chair. These are abit cheaper and lighter that way. I put my seats on factory sliders, and I just happen to have power driver seat so I can get reclined if I really want it Works great for me, I keep it slightly reclined. Passenger side sits rather straight up, i may space the front up abit to have it recline abit more. Its comfortable as it is, but would be abit better laid back some.
Old Jun 18, 2011 | 11:29 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...i think i could just get used to it. weight saving is definitely a plus but so is comfortablity
im gonna be taking my back seats out as well once i get these.
the factory sliders would be nice to keep..how'd u do it?
Old Jun 18, 2011 | 11:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Cut them up abit and installed tabs of sheet metal, forget the thickness but I think it was 3/16". Corbeau bolt pattern is wider and longer than the factory seats, so I just bolted tabs to the factory rails, that basically relocated new mounting holes for the corbeau base. BOlted to the Corbeaus and that was that
Old Jun 19, 2011 | 12:25 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
ohh i see..thats cool think ima do that to..
what harness do you have?
also, what kinda cage do you have?
Old Jun 19, 2011 | 10:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Scroth Rallye 3 harnesses. Only harness i know that carries a DOT legal certification. I may switch them out with a Corbeau 5pt harness with SFI legal certification for drag racing tho.
Cage is a competition engineering 8 pt kit that was installed by a friends shop.
Old Jun 19, 2011 | 02:28 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ah alright cool..yeah i was looking at the Corbeau 5pt harness..
hows the cage fit?
Old Jun 19, 2011 | 02:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Fits great since it was custom installed. All the bars need trimmed obviously, and my buddy did a good job.
Old Jun 19, 2011 | 09:03 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
why did they need trimming?
Old Jun 19, 2011 | 09:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
its FAR from a bolt in weld in kit.... it comes with one halo bar for main support, and then a bunch of straight tubes. Really not a vehicle specific kit other than the main tube, but it had excess material on the legs that needed to be trimmed up
Old Jun 19, 2011 | 10:57 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ahh i see..cool
Old Aug 7, 2012 | 05:14 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Anyone try out the CR1 seat? Only 1lbs more than the A4 and looks to be a bit wider and more comfortable. I am going to go with the corbeau brackets since they are supposed to be a simple bolt in and should look nice and new since i'll be installing new carpet along with it (re-doing the interior this winter.)
Old Aug 7, 2012 | 07:28 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Originally Posted by itsMikey
questions:
These are not FIA approved seats and wouldn't be approved for any form of racing.
Not in the slightest. AutoX yes, roadrace no.
Old Aug 8, 2012 | 08:35 AM
Why wouldn't these be good for road race? They have tons of side supports and are lightweight?
Old Aug 8, 2012 | 05:57 PM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
Well if your going to roadrace in any competitive class then you would be required to run an FIA approved seat. No reclining seats however are FIA approved.
If by roadrace you just mean open track days or HPDE's then yes, They will give you the extra lateral support needed. You will still be stuck running a conventional seatbelt though.
If you run harnesses then NASA and SCCA will require you to have a roll bar. Subsequently if you have a roll bar, then they require you to run an FIA approved seat with a seat back brace attached to the cage.
So if you intend to run on a road course, and depending on what you intend to do on a road course, then you will need to pick your safety equipment wisely dependent on that sanctioning groups requirements. Otherwise you may find yourself not allowed on the track.
BT283
Aftermarket Product Review
16
Jul 6, 2006 08:13 PM
DuronClocker
Nov 7, 2005 10:03 AM
19doug90
Jun 7, 2005 11:41 AM
johndinu
Apr 4, 2002 05:05 PM
IROCU69
Dec 19, 2001 01:13 PM
