Interior Restoration
Old Jul 2, 2011 | 06:50 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
I have a 1988 Firebird Formula, and was wondering what year 3rd gen interiors would be compatible with my car other than 88'.
Thanks!
-SKO
Old Jul 3, 2011 | 11:35 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Interior Restoration
There is a lot pf pieces that interchange between different years/models of 3rd gens. theres even a few things you can put in there from 4th gens (like the seats). You would have to give a lot more specifics to get the answers you seek.
Old Jul 3, 2011 | 04:47 PM
Sparkko's Avatar
1988 firebird formula 305 Automatic
Old Jul 3, 2011 | 05:12 PM
travis401's Avatar
Car: 91 Camaro RS
What peices are you needing to replace?
Old Jul 3, 2011 | 05:18 PM
Sparkko's Avatar
The carpet, seats, center column, AC and radio controls, door panels, i think the only thing that doesn't need to be replaced is the panels on the walls on the trunk...
Old Jul 3, 2011 | 05:21 PM
Sparkko's Avatar
Oh and the dash is fine except for one small crack on the drivers side, I might also replace that in the future.
Old Jul 3, 2011 | 05:35 PM
travis401's Avatar
Car: 91 Camaro RS
carpet would be any 82-92 third gen as far as i know, the seats will be the same thing. you can even get a set out of a 4th gen fbody, they bolt right in. ac controls will have to come from a 3rd gen. the radio can either be from a 3rd gen, and theres some other cars radios that work. im not all that sure on that one though. or you can just get an aftermarket radio. door panels designs differ from year to year and if you have manual or power windows. but they all fit on the doors, they just look different. dash pad would have to come from a 3rd gen bird.
Old Jul 3, 2011 | 05:41 PM
Sparkko's Avatar
Are you sure all third gen seats are compatible? I heard somewhere that the seat bolt pattern changed in 88'. The reason for this thread is that I'm trying to find a compatible donor car that I can salvage the majority of the interior from. Although I might opt for fourth gen seats!
Old Jul 3, 2011 | 05:42 PM
travis401's Avatar
Car: 91 Camaro RS
the seats might have different options, but the bolts in the floor are all the same. go 4th gen seats. they are way more comfy and can be had for fairly cheap.
Old Jul 3, 2011 | 05:43 PM
travis401's Avatar
Car: 91 Camaro RS
youll want a bird for the interior since some peices are bird specific
Old Jul 3, 2011 | 05:48 PM
Sparkko's Avatar
Well thanks for the help!
I've got my eye on a set of cloth fourth gen seats for 250.
I'm not sure if thats cheap or not though.....
Old Jul 3, 2011 | 05:52 PM
travis401's Avatar
Car: 91 Camaro RS
depends on the style, i got my plain no option cloth seats for $100 for the full set, fronts and backs.
Old Jul 3, 2011 | 05:58 PM
Sparkko's Avatar
I'm not sure about these.
After my interior revamp is over I have a broken steering column held together by tie wire to tend too! (Oh boy)
Old Jul 3, 2011 | 06:04 PM
travis401's Avatar
Car: 91 Camaro RS
you can swap a the column from a 3rd gen, youll just want to use a column that uses the same style wheel and is VATS equiped if your car is.
Old Jul 3, 2011 | 06:14 PM
Sparkko's Avatar
Yeah, I know. Its got a VATS.
I'm just going to buy one of those from E-bay
Old Jul 3, 2011 | 08:03 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Transmission: Th700R4
Axle/Gears: 3.27, 9 bolt Borg-Warner
wow i have 1988 firebird and it didn't come with a VATS, but it did have a alarm that you turn on from the fender using a key. i took it off.
Old Jul 3, 2011 | 09:42 PM
travis401's Avatar
Car: 91 Camaro RS
someone probably removed the VATS to install that alarm.
Old Jul 3, 2011 | 09:51 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Where are you located? Have a great dash pad, but little desire to ship
Old Jul 4, 2011 | 03:34 PM
Sparkko's Avatar
Wel I live in Alabama so you would have to ship it too me.
RyanJB
May 7, 2016 06:23 PM
MORREALE5
Sep 13, 2015 09:01 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
sylentnite
Sep 9, 2015 02:55 PM
scottmoyer
Sep 7, 2015 07:06 PM
