B&M Megashifter
Old Aug 14, 2011 | 05:29 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
B&M Megashifter
Post your pics of this, I'm getting mine in a couple weeks and am excited to see what it looks like!
Old Aug 14, 2011 | 05:35 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Re: B&M Megashifter
i hate the damn thing but it was in my car when i got it. i ended up painting the handle.
Old Aug 14, 2011 | 06:05 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: B&M Megashifter
Don't have a pic of mine, but I really like it. If you didn't buy the shorter cable, you might want to consider it. The shift cable that comes with it has to be looped over the transmission. Not a real big deal but the extra length can result is a really stiff shifter. Good luck with your project. Oh, yeah. It will take longer to install than you think. I would recommend having a friend help you out.
Steve
Old Aug 18, 2011 | 08:09 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: B&M Megashifter
Dont get it!!!!!! i hated mine. It was a PITA to drive. I got the short cable and routed everything PERFECT and it was a bitch to shift. My wife couldnt drive the car it was so bad. The thing i hated the most besides being able to bech 300lbs to shift it was you have to ratchet it all the way down to 1st you cant just yank it all the way down then ratchet up. This was on my old 83 i had. My 89 will be getting a hurst and we will make it work with the stock consol.
Old Aug 18, 2011 | 08:27 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: B&M Megashifter
I've got a barely used one if you wanna buy it. Not planning on using it.
That said, I didn't like it. It got way too hot, and just was a pain to use.
Old Aug 19, 2011 | 05:19 PM
891-92camaro's Avatar
Car: 92 camaro 25th anniversery
Engine: 350 TBI
Transmission: 700 R4
Axle/Gears: 3.73 9 bolt
Re: B&M Megashifter
in the process of putting in new carpet and patching floor rust, it does shift a littlie hard from park to reverse but is not a bad shifter and makes it easy that it will fit under the stock consol
Attached Thumbnails B&M Megashifter-0802111821.jpg   B&M Megashifter-0802111748.jpg
Old Aug 20, 2011 | 11:37 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: B&M Megashifter
have installed a few of them.(6). smoothing working shifter.
even a girl can use it.. dont know about all the hard to use installs..
if its hard to use its not in right..bottom line
this one was installed 19 years ago. and i still glass smooth. even after sitting for 8 years (dusty)
Old Aug 21, 2011 | 04:33 PM
OldSchoolGuy's Avatar
Car: 1986 Chevy camaro
Transmission: auto
Axle/Gears: stock
Re: B&M Megashifter
lmao, i like that plate above the shifter.. where did you get it?
Old Aug 21, 2011 | 05:00 PM
Re: B&M Megashifter
saw it in a small aircraft a long time ago. and had one made for my self.
Old Aug 21, 2011 | 05:20 PM
Re: B&M Megashifter
looks good, I've never driven with one so idk how I'd like it. Trying to get one for cheap though
Old Feb 7, 2012 | 04:49 PM
RMR94's Avatar
Car: 92 camaro
Engine: 305 bonestock sbc
Transmission: 700/r4
Re: B&M Megashifter
http://www.youtube.com/watch?v=g8WaB...eature=related
Old Feb 7, 2012 | 05:19 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: B&M Megashifter
you know i have been procrastinating buying and installing one of those. man i like how that works and how they look.
Old Apr 13, 2012 | 01:01 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Re: B&M Megashifter
I have one. Kept pulling the handle off. Got one from a friend for free but it's a hurst.
The boot was trashed so I made my own.
Old Apr 13, 2012 | 01:54 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: B&M Megashifter
Here's mine.....after I got rid of the Megashifter (I hated it), and went with the B&M Pro Ratchet......oh, and a 4th gen center console.
Old Apr 14, 2012 | 05:44 PM
Re: B&M Megashifter
The center console with that shifter looks nice.
How hard was console and shifter install?
Would be nice if the chrome part was black.
Old Apr 14, 2012 | 06:14 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Re: B&M Megashifter
Thanks man, it takes patience and cutting and removing the existing shifter components on the 4th gen console to make it work. Also, you have to drill your own holes, the existing ones won't match up. You will have to shim it to the correct height on the back. The cover piece is actually trimmed away just under the console, which you can't see. The factory B&M shifter cover is too big and presses up against the console, which could cause the plastic to break.
The chrome stick, **** or shifter cover can all be painted to whatever works for your car. I thought about painting the shifter cover black and putting a black ****. I'll do it when I get bored.......
Old Apr 15, 2012 | 05:30 AM
Re: B&M Megashifter
I'll look into changing mine out. Seeing as my wife has her go do something and leave me to go shopping. OK shoes and **** for her, console and shifter maybe new seats for me . Lol
I'll paint the base with truck bedliner spray to match the grain of the dash.
Old Apr 15, 2012 | 04:04 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Re: B&M Megashifter
That sounds like a good idea....should look really nice. However, you may find out that you like the contrast more than blending everything in. That's actually what makes it look so unique.
Just something to think about.......
Old Apr 19, 2012 | 11:49 AM
Re: B&M Megashifter
True, chrome against black is pretty badass looking.
Is the button on top for nos or trans brake? Or is it the release mechanism for reverse lockout?
Old Apr 19, 2012 | 12:34 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Re: B&M Megashifter
Line lock....for heating up the slicks at the drag strip.
Old Apr 19, 2012 | 10:00 PM
Re: B&M Megashifter
Or line lock just to irritate the neighborhood. lmao
Old Apr 19, 2012 | 10:09 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: B&M Megashifter
I bought a used B&M Megashifter & I've ended up changing directions so I won't be using it. $75 + shipping if anyone is interested.
Old Apr 19, 2012 | 10:19 PM
Re: B&M Megashifter
Which one the mega or the pro?
Old Apr 19, 2012 | 10:21 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: B&M Megashifter
I never understood what the did that the stock shifter doesn't do..
Old Apr 19, 2012 | 10:22 PM
Car: GTA
Re: B&M Megashifter
Mega
unknown_host
Aftermarket Product Review
Aug 11, 2001 08:44 AM
jayman350
May 18, 2001 08:23 PM
jimbo
Mar 14, 2001 05:35 AM
STL1994
Feb 17, 2001 02:41 AM
Fastbird
Nov 5, 2000 10:47 AM
