Cargo/T-top well cover. Post pics and how you made it
Old Aug 23, 2011 | 07:06 PM
88gunmetalgta's Avatar
I haven't been in the interior board too much, but I saw a couple of nice looking interiors and kinda got motivated to relocate my sub, and hide the T-top well under a solid cover. Since my transmission is out, and I'm broke, it seems like the perfect time for a cheap project!
Old Aug 24, 2011 | 08:11 PM
Re: Cargo/T-top well cover. Post pics and how you made it
No one's made a custom hard cargo cover panel? Guess I'll be the first then :P
I'm thinking something like 1/8" hardboard, with like 3 or 4 laminated strips about an inch and a half wide forming a perimeter around the panel for stiffness. Should be rigid enough without weighing a ton. Maybe I'll end up making it hinge longitudinal so the passenger half (well not exactly half, it would have to clear the hatch pull-down bump in the rear plastic) opens to reveal my battery box and amp, and the drivers side half is solid and hides my sub box. The sub half would be attached directly to the top of the sub box, which will also have to be supported off the floor somehow since I wouldn't build the cover to support a ton of weight like the box hanging off of it.
Old Aug 24, 2011 | 08:23 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Are you thinking of doing something similar to what the 2nd gen Ford Escorts had? That's what I'm envisioning- a board/cover that raises and lowers with the hatch.
Great idea- my sub box sits too high to do anything like that.
Old Aug 24, 2011 | 08:58 PM
No, I guess I was a little unclear. I'm thinking of something very similar to the factory hard covers. I'll modify this pic a little later to give some visual aids
Old Aug 25, 2011 | 11:46 AM
A visual:
Attached Thumbnails Cargo/T-top well cover. Post pics and how you made it-123.jpg
Old Aug 25, 2011 | 02:44 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Id love to see the end result...
Old Aug 25, 2011 | 05:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have seen one like that , i would be very interested in one . if the person is on this forum that had it , please post some info. . my present camaro does not have the window shade style cover . i miss the cover , cheers .
Old Aug 25, 2011 | 07:01 PM
Anybody have any ideas for a latch/catch that would look at home back there? I'd just use a cylinder lock like whats on a toolbox, but I'd rather not have another key on my keyring. I'm thinking I will use simple aluminum angle mount brackets for the hard side. A couple of stealthy black flat head cap screws will allow for easy installation and removal.
Old Aug 25, 2011 | 10:28 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
What about a simple slide latch.....we have one on our outdoor storage cabinet, as well as on my daughter's car for the 'door lock'. Basically a channel on one surface that a flat piece of plastic with a nub for a handle on the other latched surface slides into to secure the door. Don't know where you'd score one.
Old Aug 26, 2011 | 12:27 AM
I think this one will work good. $14.74 on Amazon. Although after thinking about it, with the sub being in such close proximity to the panel, I might have problems with the vibration making it rattle. maybe a "lift and turn" type compression latch would work better.
I'm also thinking a solid perimeter around the hatch would work a little better too. As shown in the pic.
Attached Thumbnails Cargo/T-top well cover. Post pics and how you made it-124.jpg
Old Aug 26, 2011 | 12:32 AM
GShipp85Trans's Avatar
Car: 1985 Pontiac Firebird TransAm
Old Aug 26, 2011 | 12:38 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Subscribed
Old Aug 26, 2011 | 12:51 AM
Originally Posted by GShipp85Trans
Originally Posted by jchaussee
Subscribed
Heh, now I guess I gotta follow through with this
Old Aug 26, 2011 | 12:54 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Mine's not hinged, but easily removable to gain access to the amp.
Expanded metal covered in acoustic carpet (speaker grille carpet)...
In place, it hides all and protects the amp and sub from shifting cargo...
What it covers...
Old Aug 26, 2011 | 01:02 AM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
sounds like a plan
Old Aug 26, 2011 | 01:17 AM
I like it. How much does it weigh? looks like 1/2 or 5/8" thin wall square?
Old Aug 26, 2011 | 02:01 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
What it covers...
Do you know why Amps have those raised metal lines that usually run side to side or up and down? They are called cooling fins. Heat rises so there must be at least 2 inches of clearance between the amp and the custom cover and of course an open section which allows the air to circulate. Thats why you'll never see a certified car audio installer mount an amp under the rear deck in the trunk unless the amp is of brand and has a thermal activated cooling system. Your basically playing with fire. Even if your amp has a cooling fan, there still is no ventilation to allow the radiated heat caused by the MOSFETS to ventilate.
Old Aug 26, 2011 | 07:48 AM
I don't think the cover itself would cause problems in this case, it looks to be a couple inches off the amp and it is thin, ventilated material to allow the sound through.
Mine will have a few cu ft of free air space to cool, but it's also about a quarter of that size
Old Aug 26, 2011 | 10:38 AM
Good point. With the subs pounding, the sound pressure level would just push and exchange the different air temps.
Old Aug 26, 2011 | 01:32 PM
Al Hasse's Avatar
FWIW, the amp was installed by a MECP certified technician. It only looks flush mounted, the facad around the amp is open on the ends, and yes, the cover sits a few inches above everything. In the 4 years it's been installed, I've had zero issues with heat.
Old Aug 26, 2011 | 01:58 PM
Well not all certified installers are the same. Some will cut corners to make an install faster. Many think that the general public is dumb. Well that's not the case in my position. Hell, I used to order the free audio installations guides from Crutchfield back in 1997. So believe me. I know what I'm saying (but I don't know everything) Not all installers are honest in their workmanship.
Old Aug 26, 2011 | 02:21 PM
4 years and still going strong? Nice. Good for you man.
Old Aug 26, 2011 | 08:35 PM
A good indication of whether or not your amp has adequate ventilation is feeling the top. If its anywhere north of *warm*, you may want to consider a different mounting strategy
Old Aug 26, 2011 | 11:59 PM
The way I bump my system doesnt even amount to your claim. If you put your hands on my super hot 1600 watt Sony XPlode mono-block amp, you would not be saying those words. I have my amp exposed to the open air. After about 5 mnutes of hard pounding Nuthing But A G Thang, you would wonder how these amps can run so hot and still keep on pounding for hours. Here is my system...
BADNBLK
Nov 16, 2016 09:12 AM
aaron7
Aug 17, 2016 06:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
1985chevydude
Aug 20, 2015 12:29 AM
