85 z28 Gear Shifter Knob, NEED ADVICE!!!!
Car: 1985 z28
Engine: 5.0 LG4
Transmission: Built 700R4
Axle/Gears: 3.08
85 z28 Gear Shifter ****, NEED ADVICE!!!!
I have an 85 z28 and I have all the interior stripped on the inside because I'm installing new carpet and getting my seats upholstered. But I need a gear shifter **** as well for an automatic tranny. Mine has the round one with the push button.
Does anyone know if the 87-92 automatic ***** will fit? Or even the 93-02 automatic *****?
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
Re: 85 z28 Gear Shifter ****, NEED ADVICE!!!!
they should fit, i have a 94 **** on my firebird, i also have a fake leather **** from a saturn but i didnt like the way it feels, just go to a junk yard and find some, i paid a dollar for both of these
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
NO they won't. I know because I ran into this problem. The newer style shifter **** uses a different style clip than the round style. To get and use the newer style ***** you need to get the newer style shifter assembly. My guess is 88-up because they all use the clips thst go into the front. Mines from a 90
ok, my bad, but if thats the case then its 86 and up because the fit just fine on mine
Engine: L31 350
mines an 86 and had the round shifter ****... it wouldnt work because it doesnt have the slit in the front of the shifter rod to let the clip slide into it, he needs an 88-up shiftetr assembly
If and when you go to the newer style shift **** where it is a "t" type handle let me know i recover them in new leather in what ever color stitching you want for $40 shipped. if you want some pics of my work look on fiero.nl under username mmeyer86gt/gtp
ok, so, then now im wondering what hasnt been molested in my car -_- BUT i found a round **** at the junk yard today, if you want it let me know and ill grab it for you and how do you get it off anyways? i couldent figure it out
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got a couple of round ***** with good buttons and at least one circlip that holds it on. Signs of use, but works good if you can't find one yourself. Can send pics and more info to your email if interested.
Henry
You will need to still have the plastic rod that goes down the shaft and actuates the shifter mechanism, I don't have that
Henry
Engine: L31 350
i will say henry is a good guy to buy from, iv bought from him in the past.
Car: 1985 z28
Engine: 5.0 LG4
Axle/Gears: 3.08
Mine still has the plastic piece the triggers the mechanism for shifting.....I would definitely like to see some henry. I'm off at college right now so my dad removed the shifter ****...Before it was removed you could spin it around like it was stripped....He couldn't get it off so he had to cut it through the ball to get it off....how do the ***** properly come off and on???
Car: 1985 z28
Engine: 5.0 LG4
Axle/Gears: 3.08
http://www.ebay.com/itm/82-92-Camaro...item35b8a093f6
Would a shifter **** like this work on my 85??
Engine: L31 350
No, that's the kind that you need thr newer style assembly for. Unless you have to change thr assembly you can only use the ball shifter ****
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
