Seatbelt is busted.can i use 4thgen?
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
My front driver seatbelt doesnt stay locked in place all the time.Im worried it may just come off and I get a ticket for not wearing my seatbelt.Are the 4thgen buckles direct fit replacements for our cars.Its easier to get those than trying to replace with 3rdgen.Would I also need the entire 4thgen seatbelt itself?Need to figure out if I can just repair them or invest in safer seatbelts all around.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Seatbelt is busted.can i use 4thgen?
I would contact user Rcar7395 and see if he has one.
https://www.thirdgen.org/forums/member.php?u=46723
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You can buy a repair kit for those.
Engine: 2005 LQ4
Axle/Gears: 3:54
Where can those be found.I was told they dont make kits for these anymore?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I installed 4th gen belts in mine....BUT..in order for the bottom to bolt up and seat correctly...you have to replace the door dill plate with an older style door sill plate. Once you do that....your good to go
Engine: 2005 LQ4
Axle/Gears: 3:54
Which plate are you referring to..have any pics? 4thgen front and black seat belts are cheap on ebayIm going for black and grey theme on the inside of the car aswell.Maybe I can make a plastic plate and dye it grey all depending on why they dont fit right.
Engine: 5.7
here is a search link to a few ebay auctions. Look through them...and you can see the difference between the 82-84 and the 85-92. You need the 82-84 sill plates to work correctly with the 4th gen seat belts
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
Engine: 2005 LQ4
Axle/Gears: 3:54
ok I see now.The seat belt comes out through the sill plate where as my 87 has a seperate cover that hides the bottom bolt assembly
Engine: 5.7
Engine: 5.0 EFI
http://thumbs4.ebaystatic.com/m/mOLq...zSLMeA/140.jpg
http://www.ebay.com/itm/82-92-NOS-Ca...item19cc568abb
Engine: 2005 LQ4
Axle/Gears: 3:54
Thanks guys..Im ordering a set of those for now.Cant go wrong at that price.
xbazzarex
Dec 1, 2015 05:25 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
