Issue with dashpad fitment
Old Jul 15, 2012 | 10:05 PM
Nyczbubba's Avatar
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
Ok so my dashpad is cracked and messed up so I bought another one from a guy on craigslist. If you look at it, it looks similar. Until I try to put it in and it didn't fit. The length from door to door is fine. The length from the windshield to end of dash is not. It is too short. When I line up the vents I am short about an inch to 2 inches. What car do you guys think this came off?
Old Jul 15, 2012 | 10:21 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Issue with dashpad fitment
A firebird. The dash pad is shorter on the birds.
Old Jul 15, 2012 | 10:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
what do you have, a Chevy or Pontiac??
Old Jul 3, 2018 | 11:26 PM
Anderson84's Avatar
Car: 1984 Camaro Sport Coupe
Engine: SBC 355
Transmission: Turbo 350 w/shift kit
Axle/Gears: 10 bolt 3.55 gears, locker
I know this is a old thread, but I am having a problem with my dashpad not fitting in the opposite of what was said. It is like my dashpad is too long from door to door, when the door shuts it lifts the front of the dashpad about a half an inch. Interior was not together when i got the car so am trying to figure out how to put it together, am i missing something?
Old Jul 4, 2018 | 02:29 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Old Jul 5, 2018 | 10:33 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
FYI: A Firebird and a Camaro dash pad are the same length side-to-side. The Camaro Pad is wider from front-to-back ("windshield-to-Lip") than a Firebird Pad. The Dash Pad shown in the pics HAS the center 'vent notch' only found on a Camaro Pad......
Not sure what would cause this ?? Crashed Car ?? Door trim not installed properly ?? Improper installation of the dash housing ?? ( Maybe the dash brackets were bent ?? )
Old Jul 5, 2018 | 03:05 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That was the first thing that came to my mind. But as you correctly point out, there are other possibilities.
Old Jul 5, 2018 | 06:39 PM
Billgluckman's Avatar
Is it aftermarket?
Old Jul 5, 2018 | 08:39 PM
Anderson84's Avatar
Engine: SBC 355
Thank you guys very much, I looked at my door trim and noticed that it need to be pushed down farther. After it clicked into place my door now closes fine without hitting my dashpad. Thank again.
Old Jul 5, 2018 | 09:51 PM
DynoDave43's Avatar
A cigar for the man from Rhode Island!
z 28 jari
Sep 14, 2021 10:03 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
