How to lower seats? I'm too tall and my head rubs against the roof.
Old Nov 27, 2012 | 05:15 PM
xMrBadDogx's Avatar
Car: 89 Camaro RS 2.8 V6
Engine: 2.8 MPFI V6
So apparently the 4th gen front seats sit a half inch lower than the stock seats in third gens. I'm looking for a way to get seats that sit even lower than that, i want them to be about 2 or 3 inches lower, but my goal would be about 4 to 5. So you guys got any solutions? I don't care what i have to do as long as the seats are comfy and it's not too hard to install. Sorry if someone already asked about this, just link me to the thread please, i spent a lot of time looking but didn't find anything. Thanks in advance, I appreciate it.
Old Nov 27, 2012 | 05:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How to lower seats? I'm too tall and my head rubs against the roof.
How tall are you? I'm 6'6" and have never had that problem in either of my cars. Its impossible to lower them by the amount you want without just simply removing the seats and sitting on the floor.
Old Nov 27, 2012 | 05:29 PM
92camarodude's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
I'm 6'5 and have bumped my head a few times but no biggie.
Old Nov 27, 2012 | 05:39 PM
87 Camaro Dude's Avatar
Car: 1987 Camaro SC
Engine: 2.8L V6
Haha dude you must be a giant! I'm 5'11" and I actually ended up raising my seat about an inch. I like to easily see over the hood.
Old Nov 27, 2012 | 05:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I'm 6'5" on 4th gen seats & have no problems & know a guy 6'7" on 3rd gen seats that has no problems.
But it can also depend on how far back you lean your seat. If I sit STRAIGHT up? My head comes close. Straight up on 3rd gen seats & I hit the roof.
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Same name almost haha
Old Nov 27, 2012 | 05:54 PM
Car: 1987 Camaro SC
Engine: 2.8L V6
Yea I noticed that after I posted haha.
Old Nov 27, 2012 | 06:06 PM
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 4.11
Yea
Old Nov 28, 2012 | 01:21 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Wow! I'm 6' 6" and I have a 4th gen with t-tops, a 3rd gen with t-tops and a hardtop 3rd gen. I wear a baseball cap all of the time and still don't have any head to roof clearance issues. Dooood must drive sitting completely erect. I'm guessing you drive a Camaro? The Trans Am and GTA seats offer a tilt feature. Does the Camaro seats offer the same?
Old Nov 28, 2012 | 06:27 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Simple solution
Old Nov 28, 2012 | 07:43 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The 3rd gens were def designed for reclined seat backs. The seats won't even go full straight. Maybe because they recognized that they didn't have enough headroom.
The pass seat seams to be the limiting factor. I think they didn't put the drivers seat any lower because they couldn't get the pass low enough to match.
I run into the same problem, I,m 5,11 but I have really short legs so I'm the same height sitting down as people 6'3
I calculated you can lower the pass seat by only about 3/4 " before you hit the floor by chopping the mounts in the front so it doesn't give much room for adj unless you don't mind uneven seats. The drivers can be lowered by at least 1.25"
Old Nov 28, 2012 | 08:12 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Move the seat up a bit and strighten up the seatback. Pop out the driver's side T top so you can see over the top. Wear goggles.
Old Nov 30, 2012 | 07:57 PM
1986_iroc_z28's Avatar
Car: 1986 t-top iroc z28
Engine: 5.0 tpi
Axle/Gears: stock posi and disc brakes
Old Nov 30, 2012 | 08:55 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
ahahahahaha @ eseibel67..
U gotta lean back a bit.. I'm 6'2 and put the seat a lil more fwd and add a lil more lean..
But then again thats how we do it in Cali anyways.. lol
Old Dec 1, 2012 | 12:45 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I don't want to appear to silly here, but if you have the money and want something DIFFERENT, you could always have a talented sheet metal guy shape some roof blisters into the roof like on the Dodge Viper! That might actually look very cool...! Everyone has different proportions, so I understand your dilemma- I am a little longer in the torso than the legs, so my head does brush the headliner a little, depending on the angle of the seat.
Old Dec 1, 2012 | 01:33 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i wonder if theres different leg/head room in these cars from year to year? ive owned lots of third gens for 25 years and im always running out of head room on my 87 iroc. never had this issue on any other 3rd gen.
Old Dec 1, 2012 | 05:35 AM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I have taken a few seats apart ...and in some GM cars ..there are small spacers between the steat and brackets that bolt to the floor ....its on my list of things todo with my Iroc ..I am over 6foot2 ...the P.O put 4Th gen seats in ...but I still want lower ...I'm even thinking about get Fiero seat brakets to see if they sit any lower .....
Old Dec 1, 2012 | 06:40 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I found out several years ago when I replaced the OEM foam headliner with a molded plastic liner that I gained over an inch of head clearance. The molded liner is contoured closer to the roof metal while the foam OEM one is manufactured flatter with a larger air-gap to the roof.
M
Old Dec 1, 2012 | 04:14 PM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
Where can i buy the one you're talking about, good thing you told me too, I'm about to reupholster my car soon.
Old Dec 2, 2012 | 07:36 AM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
It's been so long I don't remember. Probably Classic though as only recently have I started getting bits from Year One. I do remember that when I bought mine only the bare uncovered ABS pieces were available. You might want to do some research on the replacement molded headliner though. When I bought mine it came without the front metal mounting clips that are crimped into the OEM composite one. I had to come up with a non-ideal method of transferring them because I did not like the way the front edge sagged a little on the replacement liner without them. I'm getting off-topic! The unexpected head clearance was a benefit of the less than easy install.
M
Old Dec 2, 2012 | 08:40 AM
Myfirstconvert's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
6' 4" no problem...
Old Dec 2, 2012 | 09:01 AM
89GTA_wFact.CD's Avatar
Car: 89 GTA Blk on Blk w/ T's
Engine: 5.7 TPI
I wish the whole seat would slide back farther , being tall you have to have your foot tilted to drive , kinda sucks
Old Dec 2, 2012 | 03:51 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Do a search on Fiero brackets.
Old Dec 10, 2012 | 12:35 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
The stock Recaro seats sit a lot lower than the rest. I'm 6'7" and have no issues with the Recaros.
Old Dec 10, 2012 | 08:56 PM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
What do you mean stock Recaro seats? Aren't those aftermarket seats?
Old Dec 10, 2012 | 09:21 PM
Car: GTA
Nope. The Recaros were a stock option/part of an interior package in the early years. I think 82-84.
Old Dec 11, 2012 | 04:31 AM
stealtht/a's Avatar
M
All the abs headliners are this way. They are all made from a mold that was from the BACK side of the headliners. That's why they have more clearance, different shape ( hardtop overhead consoles don't work) and poor fit.
For hard top cars, the abs replacements are stupid. There are plenty of repairable headliners out there, easy to fix and will look way better than the abs.
T-top ones are harder to find.
Old Dec 11, 2012 | 06:27 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
I'm 6'5" and with a roll cage and a helmet, I still fit.
Old Dec 11, 2012 | 06:48 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Get a hair cut!
I'm 6'2 also...
Headroom wasn't my problem, leg room was... I put manual recline 4th gen seat track on my 3rd gen seat / firebird and it's amazing what just reclining the seat back a few inches does for comfort (and moving back / head back... I also got some brackets to move the seat back even more (my car is a stick shift, Knight Rider steering wheel, pods with Turbo boost buttons, etc...)...
Rafael
Old Jan 16, 2013 | 10:02 PM
xMrBadDogx's Avatar
Engine: 2.8 MPFI V6
Hey everyone, thanks for the help, i bought fiero seat rails and and 4th gen seats off a 94 firebird. Everything was a direct bolt in and I can sit up straight now.
Old Sep 21, 2013 | 08:57 PM
H8TRAFIC's Avatar
This thread has a lot of useful information! I too am hitting my head 6ft 4in. Being that the 4th gen brackets sit lower, has anyone bolted a manual one to a 3rd gen seat? Through some experimentation I figured I need 36 1/2in. between the seat bottom to the headliner. I measured from where the seat bottom and back meet. The seat is pretty much on the floor I know but its comfortable for me. Does anyone have this setup? Is my headroom goal possible by simply switching tracks?
Old Sep 21, 2013 | 09:03 PM
Car: GTA
4th gen tracks are shorter & 4th gen seat cushions are shorter. Best way is to swap seats but if you really want to keep the 3rd gen cushions in there? Just put the 4th gen tracks on. It will drop you lower, just not as low as a complete 4th gen seat swap will, but will likely give you the headroom you want.
I have 4th gen manual seats & people say my seats look like I'm laying down (back rest laid back but no visibility problems). No headroom problems though.
Old Sep 21, 2013 | 09:16 PM
H8TRAFIC's Avatar
I really do want to keep my 3rd gen seats. I just had them redone & they look awesome. Thanks for the input.
Old Sep 21, 2013 | 09:53 PM
luvofjah's Avatar
My 82 PMD seats bolted to 4th gen tracks and into the car,no problem. If you can get the manual reclining track, it makes a big difference.
Old Sep 22, 2013 | 02:10 PM
H8TRAFIC's Avatar
Awesome. Do you have 36 in of headroom between seat and headliner?
Old Apr 17, 2015 | 04:25 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Bringing and old thread back to life .....
I'm 6'5". Hate it that I always sat up so high in the car.
If you dropped a plumb bob from the top of the windshield, sitting properly in the car would have your eyes right at the halfway point. Even with the seat reclined more than I was comfortable with, I was above that point. I always felt awkward in the car. I wanted to sit low in it, not high.
The simplest solution is to simply bolt on a set of Fiero seat brackets. They will drop you right at 1". Doesn't sound like much, but it makes a HUGE difference.
The brackets bolt right in on the driver's side, but they do **** the seat at an angle. That's the way they mount in Fieros, they're so small the front wheelwells intrude on the footwells, so the seats are cocked to compensate. You can correct this with a little dremel work.
Before you do anything else, try this.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
