clock hole
Old Feb 4, 2013 | 01:36 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
clock hole
Anyone got any ideas of how to cut out the clock hole in our consoles so it will be perfectly round like a factory one? I have a few extra clocks and would like to install one but it will end up out of round with a dremel. Our consoles have the post to screw them in and you can see the hole in the casting but I think it will take a 3 inch hole saw bit to cut it right. Any ideas or has someone done this?
Old Feb 4, 2013 | 08:24 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: clock hole
Use a hole saw,you'll get a perfect hole.
Old Feb 5, 2013 | 03:52 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: clock hole
My buddy did mine.Not sure what he used but he told me he drew the outline with a compass and then did the cutting
Old Feb 5, 2013 | 05:58 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: clock hole
I cut my own with a hole saw. Just make sure you get the finest toothed one you can find, aim it level and go SLOW. If you try and push your way through it, you'll snag and crack the plastic.
No need to scribe any line as I recall...the circle can be seen on the backside in case you got that option...here's a pic of how mine turned out:
You can't tell it didn't come that way!
Old Feb 5, 2013 | 06:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: clock hole
Wow,can't even tell,good job
Old Feb 5, 2013 | 06:07 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: clock hole
Hey Thx!! I suprise myself every once in a while...
Old Feb 5, 2013 | 07:23 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: clock hole
Did these clocks have a backlight? Just curious.
Old Feb 5, 2013 | 07:49 PM
my82roc's Avatar
Re: clock hole
Yes,they get wired into the dimmer circuit same as your dash and console.I added one to both of my irocs
Old Feb 5, 2013 | 08:23 PM
my82roc's Avatar
Re: clock hole
Here is the one my buddy did for me in my old 82 camaro.I took it out before I sold the car and then put this console top with clock in my 86 Iroc.
Old Feb 5, 2013 | 08:27 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: clock hole
Confuzed1,
Personally I have never seen one. Is it a GM // 3rd gen or aftermarket?
Pic showing the face possible?
Looks interesting...
Old Feb 5, 2013 | 08:34 PM
my82roc's Avatar
Re: clock hole
Gm factory part...82-85 only
Old Feb 5, 2013 | 09:02 PM
Car: '87 Camaro
Re: clock hole
Gotcha--That's another education for me! Thanks
Old Feb 5, 2013 | 09:07 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: clock hole
Looks great! Those are some furry seats...
Old Feb 5, 2013 | 09:13 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: clock hole
Originally Posted by t-top havoc
Confuzed1,
It's definitely OEM. I took it out of another Camaro a long time ago out of the boneyard. They say "Camaro Quartz" right on them....I've actually seen them in a lot of cars. Most are scratched up pretty bad on the face since they're plastic. Nothing some plastic polish cant take care of. I'll see if I can't get a pic of my spare one in the garage tomorrow.
Old Feb 5, 2013 | 11:55 PM
abray1's Avatar
Re: clock hole
They are one of the coolest and rarest options our cars have. I have bought several over the years but was afraid to try and cut the hole. You guys are awesome at it. I can't tell it from a factory console clock. The overhead console and bose option are the other rare options that I collect. I hope my hole turns out as good as what you guys have done. They are perfect. I would like to know what saw blade they used. Brand and part number would be awesome.
Old Feb 6, 2013 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: clock hole
I'm considering cutting a hole elsewhere in the plastic, so a heads up would be terrific.
BTW, should anyone be interesed, I have an extra clock. PM me if you're interested.
JamesC
Old Feb 6, 2013 | 07:13 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Re: clock hole
Hmmm... I never knew those cars came with clocks in that location.
Old Feb 7, 2013 | 12:59 AM
abray1's Avatar
Re: clock hole
The console clock reminds me of the big floor clock (built in the floor) the hard rock had in Dallas back in the 80s. We went there in the late 80s and if memory serves it was just inide the entrance and it was about 3 or 4 feet across. The bar was a guitar fretboard with painted frets and all. A very cool place.
Old Feb 7, 2013 | 09:12 AM
my82roc's Avatar
Re: clock hole
Pic of the clock face.This one is installed in my 86 Iroc
Old Feb 7, 2013 | 02:56 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: clock hole
Yep...but only if they came with a base, non-digital display radio. All cars with digital display radios had the clock built into the display. It was a pretty standard deal for all GM car lines in the early-mid 1980s; an easy way to tell a stripper car was the analog clock.
Old Feb 7, 2013 | 04:00 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: clock hole
Makes perfect sense...most of the ones I used to see in the boneyard that had the clocks, were indeed base model cars like SC's with the 2.8's or Iron Dukes..
Hardly see any Thirdgens period around here anymore...
Old Feb 7, 2013 | 04:08 PM
JamesC's Avatar
Re: clock hole
My IROC was fully loaded with the exception of the radio which was the AM version. Thus my car was equipped with one of the 800+ analog clocks in 85.
JamesC
Old Feb 7, 2013 | 10:53 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: clock hole
JamesC
That sounds unusual....gotta be kinda rare to get all the bells and whistles with an IROC, and cheap out on the radio?
Was that 800+ among all models that year, or Just IROCs in '85?
Old Feb 8, 2013 | 06:40 AM
JamesC's Avatar
Re: clock hole
That's what I've always thought. Shoot, my car even has the rear window washer and wiper.
According the the White Book, all models.
JamesC
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Eric-86sc
Feb 25, 2016 09:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
