Convert power windows to crank windows?
Old Jul 29, 2013 | 01:34 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Transmission: TH 350 with Hughes 3500 stall.
Axle/Gears: Moser Axles and 4.10 gear.
How hard would this swap be without switching doors? I have 2 power doors I'd trade to 2 crank window doors if in KY. Help please.
Old Jul 29, 2013 | 03:37 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Re: Convert power windows to crank windows?
Come on let me get a reply, lol. I need someone who's done this before or anything about it to let me know.
Old Aug 2, 2013 | 05:05 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Take the door panel off.
There are 4 rivets holding the window regulator on. There will be 4 other holes near them that you need to use.
Remove all of the window tracks after disconnecting the motor from the harness. You WILL need something to hold the window up inside the door.
Cut the rivets off with a grinder or some other tool and punch the remainders into the door. You will need to move the regulator forwards and back to get the rollers out of the window glass track. Then the regulator comes out the large hole where the connector was connected to the motor.
Reverse for the manual track but make sure the track is in the right holes. You can either go out and get 1/4" rivets and either buy or rent a rivet gun OR use bolts on the regulator to hold it in place on the door shell. You WILL need to cut the ends of the bolts off.
Clean and grease the window tracks before reinstalling. Clean the windows when done as I'm sure you will get some grease on them at some point.
Old Aug 2, 2013 | 05:25 PM
Joe Tag's Avatar
Don't forget the wiring. To run it as the factory did (and keep it out of the way of everything)you need to pull the dash and center console loose because it runs along the firewall behind the top of the dash in a plastic sleeve. Hooks up very easy to the accessory block under drivers kick panel then a ground screwed to the body. Not very difficult, but it is the better part of a full day to do it all.
PUT BACK EVERY SCREW AND BOLT!!! or you will have squeaks and creeks
Old Aug 2, 2013 | 05:32 PM
Joe Tag's Avatar
OOPS... my bad. I was going the other way, from manual to power. Which I would do and have done.
Old Aug 3, 2013 | 04:51 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Thanks a lot man.
Old Aug 3, 2013 | 07:55 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
So in a nutshell, do the steps Joe Tag outlined. The only addition is you will need to drill a hole in the right spot for the crank mechanism.
Old Aug 3, 2013 | 08:15 PM
Joe Tag's Avatar
LOL It was maverick that told him what to do. I went off on my own little project
Old Sep 24, 2013 | 05:01 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Axle/Gears: ??????????????
don't mean to hijack the thread but I just scored a complete black and silver interior for $100 bucks, I have cranks in my car and want power do I need to get all the window tracks or will mine work just using the regulator and wiring. And to the op I would give my stuff if we weren't so far apart.
Old Sep 24, 2013 | 06:06 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Yes, you can use your existing tracks. You just need to swap over to a power window motor/regulator set up and of course wire things up.
Old Sep 24, 2013 | 06:09 PM
blue78rs's Avatar
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
cool thanks so much
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
