Help - Steering Column Repair Kit Install
Old Aug 18, 2013 | 03:40 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I bought this kit after my car was broken into (before I bought it).
I'm using these videos as a guide.
NOTE: In video 3 @0:16 (Attached Photo 2). The slide gear that comes out (also in the repair kit). I just found out I need the rod that this grabs, to start the car. This rod actually goes deeper into the column.
I believe this is something like what I need.
Lastly, I need to remove the turn signal lever and mechanism around the column to install new housing.
I'll update as I mess with it. Thanks guys.
Photo 1 is the Key Warning Buzzer Contact.
Attached Thumbnails Help - Steering Column Repair Kit Install-2013-08-18-16.00.23.png   Help - Steering Column Repair Kit Install-2013-08-18-15.58.27.png
Old Aug 20, 2013 | 08:50 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Help - Steering Column Repair Kit Install
Need help finding an ignition switch actuator rod. I'd like not to have to go to a pull a part if possible. So I can work and just wait for the part to my door. Help me out guys, thanks.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
