rear hatch not closing tight anymore
Old Oct 29, 2013 | 02:45 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Noticed today that I can move my hatch today when its closed and locked, never been able to do this before today, it locks and I hear the motor pulling down and it cones back up after I pull the hatch up. And suggestions? This is making an annoying sound going over bumps and I don't want my hatch to start leaking.
Old Oct 29, 2013 | 04:38 PM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: rear hatch not closing tight anymore
The pull-down latch is adjustable. Sounds like yours came loose.
Old Oct 29, 2013 | 05:07 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The whole pull down assembly has a couple of big bolts that keep it in place. Loosen them, move the assembly down a small amount and re-tighten. Try the hatch. Keep doing it until it's right.
Old Oct 31, 2013 | 09:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Also lube the latch and make sure the motor housing hasn't split...
Old Oct 31, 2013 | 09:15 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Might be a stripped gear....check out the second photo down here.
Old Oct 31, 2013 | 10:45 PM
Engine: L31 350
Long time no talk buddy!!! How've you been? I don't think the housing split but its possible I guess, i can year it pull down and it tighten up on the seal but like I said I can grab it and lift it like a quarter of an inch or more.
Old Nov 3, 2013 | 06:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, it's running, but barely. My less than 6 months old fuel pump has gone to junk, so I'm waiting for a new one (coming from China and should be here next week... Have to make sure I don't run the tank dry again or I'll kill this one). I've had more issues than I care to count with the MegaSquirt, but most of the current problems seem to be due to the lack of fuel flow because the pump is croaking. And I still can't seem to find a headliner. Only good thing is that it's got 17 miles on it since being finished now.
Anyways, the best thing for you to do is to take the rear trim panel off and out of the way. Lay in the car as best you can while someone else shuts the hatch and then push up on it while looking at the lower part of the hatch motor mechanism. Either the motor housing will move or the latch won't be latching properly. If the motor housing doesn't move, then it may be an issue with the gear nut inside the housing if the latch itself isn't partially releasing. Both the motor housing and the gear nut are available from TDS (if either needs to be replaced, do both at the same time AND do the nylon guides as well as those will probably disintegrate when you take and separate the actual sliding latch from the body bracket...).
Old Nov 17, 2013 | 11:38 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes I sell all the parts to repair these pull-down units. The link to my web site is over there--->
Lon Salgren
Old Dec 1, 2013 | 12:44 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
i repalced mine didnt seal at all kept getting exhaust fumes and crap took it all apart moved it down and it works fine now there is actually quite a bit of play in the motors to play with also make sure it is lubricated well they tend to try out fast for some reason hope this helped!! also just rememered this on the tracks for the motor if those plastic pieces are not snuug in the against the assembly it wont stay tight either..goodluck
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
