Dash Pad screws - information please
Old May 20, 2014 | 06:56 PM
corlando52's Avatar
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
My 1984 didn't come with a dashpad. I am putting one on now and would like to use the correct screws. Can somebody tell me what is the correct size?
Thank you.
Chris
Old Dec 26, 2014 | 09:04 PM
Jrob1060's Avatar
Car: 89 GTA
Engine: 5.7L
Transmission: ATX
Re: Dash Pad screws - information please
Corlando52, Did you ever get a reply to your question? The dash pad in my car was just laying on top of the dash and there was no hardware. I have no idea what the size of the screws are. If you were able to find out, please pass it along.
Thanks,
Old Dec 27, 2014 | 11:04 AM
corlando52's Avatar
Engine: 2.8 L
Thanks,
Sorry, no, I never found out the size as someone on this board just sent me some he had lying around. I only used the ones that attached though the vent, but I believe there are others that attach the lip of the pad to the dash as well, which are a different size I believe. Post on the wanted board for them, and also check the for sale board for someone parting out his Firebird and ask if he has the screws.
Good luck!
Chris
Old Dec 27, 2014 | 08:05 PM
Jrob1060's Avatar
Car: 89 GTA
Engine: 5.7L
Transmission: ATX
Chris, Thanks for the reply. I appreciate the tips, I'm new to this forum, so I'm still learning the ways.
Thanks again,
James
Old Dec 28, 2014 | 01:44 PM
corlando52's Avatar
Engine: 2.8 L
Thanks again,
James
Glad to help, James. Let me know if I can be of any more assistance. If you ever find out the correct size of the screws, please let me know. The ones I have are a bit rusty and I wouldn't mind replacing them with new ones.
Best,
Chris
Old Dec 29, 2014 | 04:28 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Believe these are the screws for the underside of the dash pad: https://www.fastenal.com/web/products/details/0162763
Old Dec 31, 2014 | 11:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The ones on the vents are like the long Philips on the kick panels/door sill, bout 2" long.
Underside screws are the same as other screws by a underside vent (pass side), also philps, maybe 3/4".
Old Jan 1, 2015 | 12:40 PM
corlando52's Avatar
Engine: 2.8 L
Thank you. I was looking for a thread and thickness detail, like M3 if it were metric...
Chris
Old Jan 1, 2015 | 12:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
There screws go into the foam padding, any thread will work.They're sheetmetal type threads.
Old Jan 1, 2015 | 01:18 PM
corlando52's Avatar
Engine: 2.8 L
Hi! The screws that go through the vents screw into a metal piece. Some of the screws I've tried are either too thick or too thin.
Chris
Old Jan 1, 2015 | 01:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, on the vents they go into the metal bracket for the speaker.Should be a button head.Its easy to strip the foam by over tightening.So a thicker screw may be needed.
Old Jan 1, 2015 | 02:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
These are the correct screws. Sorry, no size info.
http://www.bing.com/images/search?q=...45418228483543
Hopefully, you'll be able to view the image despite the copyright warnings.
FWIW, the vent screws are oval head (with a captive washer), not button head. This is what the factory used to install my dash pad.
Old Jan 1, 2015 | 04:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yep, they do have the washer (captive).Been awhile since I looked down there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
