Mysterious plug
Old Jun 1, 2015 | 04:49 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Mysterious plug
Found this today stripping my parts car. It was in the passenger side kick panel area. I looked in my other camaro and it didn't have it,just a hole where it should have been.
Old Jun 1, 2015 | 05:35 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: Mysterious plug
Looks like your parts car was at one time EFI of some sort. Most of the ECM wiring goes through the passenger side kick panel, while the rest of the wiring goes thru the firewall on the upper left of the engine compartment. Looks like a previous owner cut out the wiring he didn't want to keep, but left the stubs there to leave the hole sealed. What was the parts car originally?
Old Jun 1, 2015 | 05:37 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Mysterious plug
Parts car 1984 z28. My DD/ project is ans 86 iroc/z28
Old Jun 1, 2015 | 05:39 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Mysterious plug
I was thinking radio maybe because it was right by the antenna
Old Jun 1, 2015 | 05:59 PM
Re: Mysterious plug
Was it originally a carb'ed or CFI car? And except for the antenna, nothing for the radio should exit the passenger compartment. Some of the A/C wiring might have gone through there, but mostly engine control wiring.
Old Jun 1, 2015 | 06:08 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Mysterious plug
My DD/project was a lb9 305 tpi car now it's a carb. The 84 I don't know it was a roller with no eng or trans.
Old Jun 1, 2015 | 06:14 PM
Re: Mysterious plug
Your LB9 should have had wiring there originally, the 84 without knowing what the engine was not sure. But at any rate, that should answer your question. It's just a pass through for wiring with some sealant in it to keep water out of the passenger compartment. You can take it apart and use it to run whatever wiring you like, then put it back together and use silicone to re-seal it around the wires, leave it as is, or put a plate over it and seal the hole entirely.
Old Jun 1, 2015 | 06:20 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Mysterious plug
Most likely use it to seal up the hole.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
