Firebird shifter in a Camaro
Old Jun 4, 2015 | 11:25 PM
Eric Darr's Avatar
Car: 1988 Camaro
Engine: 2.8
I've searched the interior section and didn't find an answer...
I'd like to use the Camaro console and selector plate with a Firebird shifter because my daughter has a difficult time pressing the button on the 'square' ball shifter in her 88 Camaro and I was wondering if the T-handle shifter from a Firebird will work in a Camaro console. Has anyone done this swap successfully?
Old Jun 5, 2015 | 05:26 AM
nhgator's Avatar
Car: 1985 T/A
Re: Firebird shifter in a Camaro
I have the square Camaro shift **** on my Trans Am shifter,just a matter of changing the top part.
Old Jun 5, 2015 | 09:01 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Works fine, just change out as gator said. Have the T-handle in son's Camaro
Old Jun 5, 2015 | 10:15 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
T-Handle should be a direct swap. I don't think the shifter plate will be though. I suspect you will need to swap the entire center console. In the firebirds, the center console and the radio pod are two separate pieces. Are they one piece in Camaros?
Old Jun 6, 2015 | 06:59 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Numerous 80's and 90's GM floor shift ***** will work on an '87-up Camaro shifter, and the Firebird t-**** is one of them.
Old Jun 6, 2015 | 10:30 PM
Eric Darr's Avatar
Car: 1988 Camaro
Engine: 2.8
Went to LKQ in Greenville, SC today and picked up a T-handle out of an 87 Firebird. Also, plucked the near-perfect front and rear seats from it. The drivers seat bottom on the Camaro was worn through to the foam so I was looking to replace the fronts but the rear was in such good shape and it would look better to have them matching... I can't wait to get them cleaned up and installed and put the shifter handle on.
Old Jul 18, 2015 | 12:01 AM
Eric Darr's Avatar
Car: 1988 Camaro
Engine: 2.8
I've been busy the last few weeks making changes to the Camaro and thought I'd update with some before and after pictures. I got the T-handle installed and it works easier for my daughter to put into gear. I got the seats cleaned up and installed. I really like the feel and look of them a whole lot better than the Camaro seats. I had an 89 IROC years ago but these seats seem more comfortable than I remember the IROC's.
I also replaced the standard steering column with a tilt column and replaced the front seat belts.
Old Jul 18, 2015 | 09:56 AM
Yenipenny's Avatar
Car: 92 RS Heritage
As others have said, GM shifters will fit. I have a mid 80s Caddy Alante shifter in my 92 RS. It's unusual and has an unusual push button. Well, I think it was from an Allante, but I can't find one that looks like it right now.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
