Dome light wont turn off
Old Nov 11, 2015 | 02:27 PM
theking11863's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8L V6
Transmission: Automatic
So after a few months of not having it work due to a lack of a bulb and a bent bracket, my 84 firebird hasn't had an interior light since I got it. Yesterday I finally got the lightbulb and put it in only to discover that it doesn't turn off. Anyone have any ideas why this may be?
Old Nov 13, 2015 | 12:34 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Dome light wont turn off
Check the door pin/s.
Old Nov 13, 2015 | 12:52 AM
Engine: 2.8L V6
I know to check them I just don't know what I'm looking/checking for :/
Old Nov 13, 2015 | 03:35 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Push them in and out. If they don't move then they are probably the problem. My driver's side was stuck a long time ago to where the door didn't activate the light. Super easy to check and fix. That's where I'd start.
Old Nov 13, 2015 | 08:50 AM
Engine: 2.8L V6
Both buttons go in and out. Now what?
Old Nov 13, 2015 | 11:56 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Ran into this same problem on my 92. The drivers door was not pushing the pin in far enough to break contact and turn the dome light off. To see if you have the same problem, grab a helper and open both doors. Each of you push in a pin to make sure the light goes off. If it does, one or both pins are your problem. If it stays in, you've got a wiring problem(short) somewhere. Assuming the light goes off keep holding one pin in, say the drivers side, and close the passenger door. If the light stays off, your passenger door pin is good. If it stays on, then you need to look at that pin closer. Even if it stays on, do the same test on the other(drivers) door, just to verify you don't have a problem with both pins.
Old Nov 13, 2015 | 05:36 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Bad door pins or also a bad headlight switch will do it too.
Old Nov 13, 2015 | 07:16 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Turn headlight switch **** to turn off the light?
Old Nov 13, 2015 | 07:24 PM
"John"'s Avatar
Car: 91 Camaro RS
Engine: 350 crate engine 360ish HP
Transmission: T5 5 speed manual
Axle/Gears: 3.42 10 bolt POSI
This happened in light in the trunk once... I just disconnected the battery for the night (originally because it was late and I figured I'd deal with it the next day) and when I reconnected it it was fine again.
Old Nov 14, 2015 | 06:23 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
That was a fluke, just got lucky timing there.
Try turning the headlight **** like you are dimming the dash lights while you are sitting in the car with the doors shut. So that's clockwise. Turning it all the way counter clockwise you will feel sort of a soft click. That's cutting the light on to read a map or whatever people did before self light smartphones lol.
bjankuski
Nov 10, 2015 03:46 PM
HP52TA
Exterior Parts Wanted
Nov 2, 2015 09:08 AM
Alex Fields
Oct 26, 2015 05:16 PM
bjpotter
Oct 22, 2015 11:51 PM
astout82
Mid-West Region
Oct 21, 2015 02:58 PM
