Never knew this was there...
Old Jan 31, 2016 | 10:29 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Swapping the cracked dash out (on going resto) and never knew this "night light" ever existed in any of my past Z's...guess they were burned out as im certain this one is...
Old Jan 31, 2016 | 11:25 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Never knew this was there...
That's an interior accent light which goes on when the headlights are on. It's on the later cars. My '89 and '92 have it, my '85 doesn't. So I guess you could deduce it was introduced between '86 and '89.
Old Jan 31, 2016 | 11:29 AM
mjdavis68's Avatar
The dash im swapping is from an '87 Z and it has the spot for it but not the light.. If my '89 had it, i never knew it.. comical because you think you know these cars too
Old Jan 31, 2016 | 11:33 AM
chazman's Avatar
Axle/Gears: BW 3.45
It's a very lower power light which sort of puts a slight glow over the HVAC/radio area. I never knew it was there either, until I noticed my '89 seemed less dark inside than my '83.
Old Jan 31, 2016 | 05:23 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Yep, they are handy to have. My '91 Camaro had one, as does my '88 T/A.
Old Feb 4, 2016 | 11:25 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I just checked my '88 IROC...there's a little square there with a white square, which I'd assume is a lens.
That's a neat thing...I never had noticed that even being there!
Old Feb 4, 2016 | 11:53 AM
Car: 1988 IROC-Z
Pulled the cover on mine...it's a tiny bulb. Anyone got any idea what sort of bulb it is? Mine is blown, which would explain why I didn't have any idea it was there.
Old Feb 4, 2016 | 04:00 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Let there be light! A little different on a '91, it had a pigtail and enclosed bulb. I took it apart and spliced in a led.
Old Feb 24, 2016 | 10:50 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
on an '89 it is a "74" bulb
i used one of these and it works fine, as said very little light but it is noticeable and it adds ambiance to the interior
http://www.ebay.com/itm/Lot-3-Blue-T5-5050-SMD-Wedge-58-70-73-74-Car-Dashboard-LED-Light-Bulbs-/201396300985?hash=item2ee427acb9
Old Feb 24, 2016 | 01:21 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Yep my 89 got one
Old Feb 24, 2016 | 04:43 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Birds have a similar light above the radio pod. I pulled the bulb on mine long ago. It annoyed me to have the light there when the Radio and HVAC had their own internal lights that were much more visible at night.
Old Feb 27, 2016 | 10:10 PM
ledman66's Avatar
Car: '85 Trans Am
Engine: 305 LG4 4BBL
Does anyone make these or should i just splice in a led bulb/connector?
Old Feb 27, 2016 | 10:16 PM
Its probably a standard connector like for the other lights, I never actually looked at it when I had the dash panel off.
Old Feb 28, 2016 | 12:22 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
Way back in the day I drilled mine out larger and put a red gel over the opening and it shone on a figurine that sat on top of the hater controls. The.n I went to something dangling there, but after I my car was stolen and then took what I had dangling I never replaced it. I feel like it's purpose was to illuminate the ash tray.
Old Feb 28, 2016 | 06:28 AM
That Sky Guy's Avatar
Just when you think you really know these cars... learn something new every day!
customblackbird
Aug 27, 2018 01:05 PM
gearhead141
Mar 16, 2018 12:55 PM
84strokerbird
Feb 22, 2016 04:40 PM
ndevin25
Feb 4, 2016 10:27 PM
blackbeauty89
Jan 30, 2016 07:40 AM
