What works to dye the rear cargo shade?
Old Feb 18, 2018 | 02:56 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
My black cloth (not vinyl) cargo shade has faded to purple. I've searched and found threads from 2-8 years old, plenty of people post suggestions, but there are few real experiences and those are old enough to make me think there have to be better products now.
Has anyone re-dyed their rear cargo shade? What did you use? How has it held up since then?
(Ignore the faded seats, I'm talking to Lethal interiors about that now.)
Old Feb 18, 2018 | 06:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: What works to dye the rear cargo shade?
For cloth I've used the RIT liquid dye. You would need to put it in a spray bottle, roll out the sunshade and spray away. I wouldn't use any of the aerosol spray can dyes for this, too flexible.
Old Feb 18, 2018 | 09:19 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I have not dyed the cover, but I've used a product before called rub n restore that worked great on some seats, I've also used the vinyl spray for plastic n carpet with good results
Old Feb 24, 2018 | 08:54 AM
Lurbie's Avatar
Car: 89 Camaro
Before I went further I asked Princess at Lethal Interiors if she made these. Unfortunately she doesn't. So I'm looking at dyes, but have NO idea what material this is made out of and it looks like that matters. From what I've found online, it looks like I can burn some of it and see what happens, (http://info.fabrics.net/fabric-facts...dentification/) but I'd rather not try to cut some of this off to do that.
Does anyone know what type of material this cloth shade is made from? Here's what I am reading from ritdye.com
Choose the Right Dye For Your Fabric. If the fabric you plan to dye is a natural fabric (such as cotton, linen silk, ramie or wool) or is nylon or rayon, then use Rit All-Purpose Dye. If the fabric you plan to dye contains more than 35% polyester acrylic or acetate, then use Rit DyeMore for Synthetics.
Old Feb 24, 2018 | 12:17 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
I used vinyl and fabric dye the spray kind on mine a few years ago. No issues at all.
Old Feb 24, 2018 | 06:12 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Funny you ask, I just dyed mine today with vinyl and fabric dye. This pic is about half way done and you can see the line where it was almost purple.
Old Feb 24, 2018 | 09:33 PM
Lurbie's Avatar
Car: 89 Camaro
I saw that at the store today, but was hesitant because I was afraid it was going to make it stiff or cause it to bind up when I retract it. Once yours is dry I'd like to know if it makes the cloth stiffer or harder to roll up?
Old Feb 24, 2018 | 09:36 PM
rdhanded2's Avatar
Top Answer: 1
That is exactly what I used a couple years ago. works like normal and no stiffer than it was .I would post pics but in storage til spring.
Old Feb 24, 2018 | 09:58 PM
Lurbie's Avatar
Car: 89 Camaro
Thanks guys. I'm going to give it a try as soon as it warms up outside. I don't think it will work well to spray it at 35 deg F.
Old Feb 25, 2018 | 07:16 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Go with the vinyl and fabric dye from SEM or Dupli color. I've used it on seats, carpet, and interior plastics with no issues. With proper prep it will last a long time.
Old Feb 26, 2018 | 07:01 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
My springs are wore out anyhow so I really couldn't tell a difference in rolling it up but if it is stiffer it certainly isn't bad to deal with.
Roc Me 2
Mar 1, 2013 10:48 PM
AMM_87TA
Dec 14, 2012 05:58 PM
90Camaro4ever
Jul 24, 2009 03:58 PM
83T/A_Dave
Apr 25, 2001 08:38 PM
25thRS
Apr 8, 2001 01:29 PM
