Modify stock seat Seat-backs to lock
Old Jun 17, 2018 | 06:44 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hi all,
I haven’t found a thread on this since it seems most upgrade their seats to newer styles but my seats are in really good condition, quite comfy, and I would like to keep a stock look. So question is:
Is there anyway to setup my seat backs to lock?
From the owners manual, it seems they only lock under very drastic stops (accidents), however, semi-drastic stops (spirited driving through mountain roads) cause the seat backs to move forward a bit with me and I would like to fix this by getting them to lock somehow.
Any ideas?
Old Jun 17, 2018 | 06:55 PM
Drew's Avatar
Re: Modify stock seat Seat-backs to lock
Take a set of recline mechanisms from a 4th gen and bolt them to your 3rd gen seats.
Old Jun 17, 2018 | 07:01 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
oh wow! I’ve seen 4th gen seats are bolt one but can I remove my seats and just bolt them onto a 4th gen mechanism and bolt that setup back in my 3rd gen?
do you know if there’s any threads on this?
Old Jun 17, 2018 | 07:09 PM
Drew's Avatar
4th gen seats are generally just a slightly modified version of thirdgen seats. Take the plastic covers off the hinge next to the recline lever, there are two bolts on the bottom, two more on the top, and the recline mechanism/spring/lever, etc will all come off it one piece. 4th gen piece should bolt right on. No need to even remove the seats from the car.
Of course I'm assuming they're the same bolt pattern. They could be slightly different, but I doubt it.
Or try this.. https://www.thirdgen.org/forums/inte...ml#post6228373
Old Jun 17, 2018 | 07:49 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Nice! Sounds like there’s a solution then. I’ll probably go to the junkyards and find the 4th gen mechanisms. Do you know if they’re still pretty available at the junk yards? I live by a few pick n pulls but don’t really ever look at the 4th gens.
Old Jun 18, 2018 | 04:45 AM
Firebrewed's Avatar
Car: 86 Trans Am
Have a look at my post on this thread for an easy solution. First post on here after 10 years of lurking, who'd have thought I'd get the chance to use it again so soon
https://www.thirdgen.org/forums/inte...ever-lock.html
edit, just noticed already linked. You can probably see why I'm not a prolific poster :-)
Old Jun 18, 2018 | 10:36 AM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
thanks Firebrewed! I seen it but I thought “how’s a hair clip going to hold up over time, or even if I accidentally forget that I have a lock mechanism and I push the seat forward” also... I thought about how the 4th gen setup may still let us move the seats forward in a conventional manner vs removing a clip. What do you think ?
Old Jun 18, 2018 | 04:16 PM
Firebrewed's Avatar
Car: 86 Trans Am
It's been on mine 5 years now so seems to be holding up pretty good.
The clip isn't doing the locking, it simply holds the little weight which activates the lock in the forward position so the seat acts like its at a steep angle all the time. You don't remove the clip to move the seat back just lift the lever in the usual way and the weight is pushed back against the clip releasing the lock.
You could always have a go, if you're not convinced go the 4th gen route. We can't easily find US car parts here so sometimes you just have to make stuff work so my choices were a bit more limited than yours. Either way, hope you get sorted.
Cheers, Gary
Old Jun 18, 2018 | 04:36 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Cheers, Gary
Wow, ok! That makes sense ... In that case, all my concerns aren’t real... ok! I’ll give it a try and see how it goes!! Thanks a ton!
dutch89gta
Sep 18, 2003 09:21 PM
AJ_92RS
Jun 19, 2001 09:07 PM
AJ_92RS
Jun 19, 2001 06:42 PM
Jim 86 Bird
Car Audio
Mar 13, 2001 02:50 PM
