Direct bolt in easy find seats 84 camaro
Old Jul 21, 2019 | 09:48 AM
zrafferty's Avatar
What are the direct bolt in seats that I can easily find in junkyard. Need the tracks perfect allignment as mine rotted off.
I know of the 4th gen are direct swap. I have heard of S10 but no proof on that yet.
Old Jul 23, 2019 | 12:28 AM
83AQ9's Avatar
Car: 1983 Recaro T/A
Engine: GMPP 350HO Carbed
Re: Direct bolt in easy find seats 84 camaro
Where are you located? I'm in MN and currently have a beautiful Camaro interior that my buddy put in when he owned my car. Only problem is I'm a Knight Rider dork and I want my Recaro interior back. Felt bad telling him, he put in a ton of work to find and clean nice parts and it looks great, I'd like to get them to someone who would really appreciate them.
Old Jul 29, 2019 | 08:16 PM
zrafferty's Avatar
I'm located in ny
Old Jul 30, 2019 | 09:17 PM
83AQ9's Avatar
Originally Posted by zrafferty
I'm located in ny
Eh, probably not worth shipping that far for cloth junkyard seats. Have you tried searchtempest?
Old Oct 29, 2019 | 09:06 PM
zrafferty's Avatar
Found a nice set on Craigslist with 4th gen mounts for 50 bucks using them into my 91 vs 84 though
Old Nov 3, 2019 | 08:42 AM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
No matter what seats you get I'm pretty sure you need to swap over your 3rd gen sliders to them. I just installed 97 Sunfire GT seats in my 82 and needed to re-use the 82 sliders.
Old Nov 5, 2019 | 08:17 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
4th gen seats are a 100% direct replacement. Have a nice (looking) charcoal set front and rear in my car, came out of a 98 Firebird that was rolled over.
Unfortunately I was all excited about how nice they look and realized later that the foam on the drivers seat has seen better days. Still better than my factory set where the drivers seat was showing the metal frame on the side of the seat.
So with that being said my recommendation for the OP would be to make sure to test out any potential donor seats and make sure you like them first.
Old Dec 5, 2019 | 10:31 PM
Alfisti's Avatar
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
It's a little bit of work, but I bet the passenger and driver seatback foam is the same. You could swap the foam side to side.
I just did this on my 86, I found a good passenger seat and swapped the foam over to my driver's seat where the rods were poking out of the foam. Much comfier.
Old Dec 21, 2019 | 12:50 PM
zrafferty's Avatar
I know I have heard people using camaro seats in blazer just no verifications on opposite spectrum.
im short only 5”6 so atleast height won’t bother me it will just help lol
Old Dec 22, 2019 | 08:06 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
If you swap the Camaro brackets to the Blazer seats it'll likely bolt in without issue, unless for some reason they are too wide or too tall.
Most GM seats to my understanding will almost always have different brackets, but the place the brackets bolt to on the seats themselves are always in the same place.
Old Dec 23, 2019 | 02:12 PM
zrafferty's Avatar
That is good to know information thanks I’ll do more research see if there any change between years.
i got a 91 and 84 I’m in mist of rebuilding.
both in desperate need of new seats 84 I’m still working on finding a way to fix the mounting tabs on body as flor board on driver rotted and bolts snapped off and twisted
Ron U.S.M.C.
Feb 10, 2013 10:09 PM
Free Bird
Jul 18, 2002 11:38 AM
ONEFINE8T9
May 25, 2001 12:50 PM
RoadRocket L98
May 23, 2001 08:36 PM
