Reversal switch or pull down motor
Old Mar 16, 2020 | 04:43 PM
frebor72's Avatar
My pull down motor won´t close the hatch. Sometimes it works but sometimes not. If I tap the motor housing it does goes down. But how can I tell if it is the motor or the switch? The are really close to each other. If I compare to my friends car my motor is slower and is louder. It also slows down just before the reversal swith clicks. Any ideas?
Old Mar 16, 2020 | 06:11 PM
Drew's Avatar
Re: Reversal switch or pull down motor
Clean out all the dirty old dried up grease. Lube with fresh grease, see if it makes a difference.
Last one I had apart, the grease was the same consistency as an old crayon. Obviously a solid isn't a great lubricant.
Old Mar 17, 2020 | 12:47 AM
frebor72's Avatar
Will try that
I also read that worn down motor brushes might cause similar problems. Is that a possibility?
The problem only occurs when I close the hatch. Never when I open it.
How do I measure motor voltage? Wire colors?
Old Mar 18, 2020 | 03:40 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Yes, clean out ALL that old, hard, waxy lube. Re-lube with white lithium or something known to be plastic compatible.
When I did mine, I pulled the motor cover off to lube the armature bushings. There was no abnormal brush wear.
Old Mar 18, 2020 | 05:28 AM
frebor72's Avatar
Thanks! I will do that and also check the motor brushes, windings and collector. Good to know that it is possible to open up the motor
Old Mar 20, 2020 | 02:19 AM
frebor72's Avatar
It´s all working for now. Hope it stays that way.
Inside the motor there is a switch that I presume are temperature controlled. by a bimetal. Is that to protect the motor and how does it work?
Old Mar 20, 2020 | 04:22 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
As I recall, there was no such thing inside my motor.
Old Mar 20, 2020 | 07:15 AM
frebor72's Avatar
It was located under the brushes. Since I can get the pull down to start working by tapping the motor I figure that the problem might be this switch or the reversing switch.
But right now everything works. The motor was in good shape by the way
Bavooz Flo
May 18, 2020 01:14 PM
frebor72
Mar 16, 2020 04:42 PM
brocknstock
Sep 6, 2009 10:00 PM
Jay3wpb
Jan 15, 2005 05:04 AM
