Is this heater/AC box control part available?
Old Oct 6, 2021 | 11:52 PM
1988-1992 Z 28's Avatar
Car: 1987 Firebird
Engine: 350 not original
Transmission: automatic
I've had my 87 Firebird since July. There was a hissing coming from the heater AC controls and I found the fix for that mentioned on this forum and fixed that this evening. Then I discovered that the lower control lever cable (hot to cold) moves the cable end located at the bottom of the heater/AC box but the V shaped lever attachment is missing. I saw a good picture of it on a repair video. A stud about 3/8ths of an inch sticks down which I assume is part of a flap that it is supposed to move. Is that V shaped part available? I've looked some but haven't found one or how to install it without it coming back off. Thanks
Old Oct 7, 2021 | 10:15 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Is this heater/AC box control part available?
Which part u talking about? I just took off whole assembly heater box from an 88 IROC.
Old Oct 7, 2021 | 06:53 PM
Car: 1987 Firebird
The lever you see on the video with the cable is what I need that's missing. It has a round flat washer that fastens it. That's the picture you see. In your pictures your box looks different or there isn't a picture of the bottom of the box. Thanks.
Old Oct 7, 2021 | 08:11 PM
topduarte's Avatar
Transmission: auto
Send me a pic of the video on the part you are talking about
Old Oct 7, 2021 | 10:30 PM
Car: 1987 Firebird
Do you not see the YouTube video picture under my post? It shows up on my end. Anyway it is titled :
. The picture is from the bottom looking up. It looks like I see the cable on yours. It is the cold and hot selector cable controlled from the bottom selector on the dash control. It shows it at 1:42 into the video.
Last edited by 1988-1992 Z 28; Oct 8, 2021 at 08:15 AM. Reason: More information to clarify
Old Oct 10, 2021 | 09:59 PM
Platinumalloy's Avatar
Are you talking about the bracket that the cable is clipped to
Old Oct 10, 2021 | 10:18 PM
https://www.thirdgen.org/forums/inte...lend-door.html
Old Oct 10, 2021 | 10:55 PM
Car: 1987 Firebird
Yes that is the part seen in the 3 pictures. The bracket in the video I watched shows it with 2 studs about an inch apart which makes it a Y shape. It only needs one stud since there is only one cable that attaches. I know the rod that sticks out has a D shape. It sounds like it isn't reproduced but since it is pressed on it looks like I need to find one on an old heater box. I'll have to think about how to make one also.
skinny z
Oct 7, 2010 04:33 PM
87camaro kid
May 30, 2009 03:05 PM
John in RI
Sep 25, 2008 10:27 AM
maroon91rs
Jun 7, 2002 09:10 AM
