module on HVAC box behind dash id
Old Jun 5, 2022 | 04:11 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
should’ve taken pictures but now dash is back on
Noticed a module to the right of the hvac unit (hanging off the hvac unit) with a chip connector but nothing to plug into it. Black box with looked official GM rather than aftermarket. Any ideas what this might be?
tried searching and might be a cruise control piece? But seems an odd and no connector but my cruise worked fine?
car is a 91 TA 5speed
Any steers would be great
Old Jun 5, 2022 | 05:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: module on HVAC box behind dash id
What you describe sure sounds like the cruise control module, and my only idea as to why it isn't plugged in, but your cruise control works, is this;
Perhaps sometime in the car's past the cruise module failed, and someone plugged in a new module and tucked it up into the dash somewhere, without putting it in the proper location?
Old Jun 6, 2022 | 11:58 PM
GTA1990's Avatar
Car: 1991 Trans Am
Yes possible it’s had some ‘customisation’ in the past
Old Jun 7, 2022 | 01:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
And you are NOT talking about one of these, right?
Old Jun 7, 2022 | 01:31 PM
GTA1990's Avatar
Car: 1991 Trans Am
Yep none of the above. This is attached to the hvac box behind the dash. It’s about where the ECU sits but slight to the left and behind it
black box with a single chip in it (quite loosely enclosed, rattled about a bit)
Old Jun 7, 2022 | 01:35 PM
GTA1990's Avatar
Car: 1991 Trans Am
Also to add not the VATS module which is attached to the dashboard
DynoDave43's Avatar
Maybe it was put there by the government. Have you been speaking ill of parliament?
Old Jun 7, 2022 | 01:47 PM
GTA1990's Avatar
Car: 1991 Trans Am
Lol, with Boris as PM they’d have to track most of the nation
I think OrangeBird is right and it’s the Cruise Module perhaps repositioned on later airbag cars. I have a pro-flo intake and no immediate provision for the cruise cable so no loss if so
Old Jun 7, 2022 | 02:05 PM
GTA1990's Avatar
Car: 1991 Trans Am
For closure, looks like it is the cruise module per post 6 of the linked
https://www.thirdgen.org/forums/tpi/...e-control.html
thanks all
Old Jun 9, 2022 | 09:46 AM
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
Related question. I'm building a 1990 with an LS1 so not a big deal (I can't use this module, right?) ... But my car does NOT have a cruise control stalk on it. I was surprised to find this cruise module in the passenger side dash because of that. Did all cars get it? or was my stalk perhaps swapped or something? Thoughts?
Old Jun 9, 2022 | 08:44 PM
DynoDave43's Avatar
Do you still have your vehicle SPID label? If so, look for code K34, Electronic Cruise Control.
Old Jul 7, 2022 | 08:25 PM
rearview's Avatar
This label seems to be long gone, sadly.
irocman7
May 25, 2018 04:50 PM
FlyDoc
Feb 9, 2009 08:40 AM
Firebird_dave7
Feb 16, 2008 06:13 PM
84z28350
Sep 22, 2005 09:59 AM
Brett
Aug 24, 2002 03:43 PM
